It is currently Sun Nov 08, 2026 5:13 pm
Vehicle: Ducati Monster
Post Posted: Mon Jan 09, 2012 7:19 am
called a wheel joint today to get a price on getting my rims flipped, they said $110 per wheel, whats the consensus? expensive or not?
i dont mind paying for good work, but that still sounds a little bit rich to me
Post Posted: Mon Jan 09, 2012 7:22 am
Cut and re-weld? If the work is good then probably not too bad. You'd hope paint was included tho
Post Posted: Mon Jan 09, 2012 7:31 am
expensive... if it doesn't include paint
Post Posted: Mon Jan 09, 2012 7:37 am
expensive for sure...
i got rims made brand new for $148ea - http://www.auszookers.com/index.php?nam ... ic&t=16613
thats unpainted, but its a new center and a new rim welded to my specs.
Post Posted: Mon Jan 09, 2012 7:48 am
Expensive.
Offroad solutions will do them for $50-60 per rim. Maybe less.
thought so, and paint not included
Post Posted: Mon Jan 09, 2012 7:50 am
alien they look the goods! freight is a bitch though, might look at some engineering places, see how they go
Post Posted: Mon Jan 09, 2012 8:38 am
Hi
What rims are they and what do you what to achieve,
I bought new rims for $60 each with minus 13 offset.
Manaroo12
Post Posted: Mon Jan 09, 2012 8:40 am
getting rims flipped usually results in a BIG offset (like mine, which are -38mm) - so he's most likely after more width without using wheelspacers (which are illegal).
Post Posted: Mon Jan 09, 2012 9:09 am
they are black king sunnys, 15 x 7 -13 (roughly measured), just like Alien said, i don't want to use wheel spacers.
more track width is what I am chasing, have NT diffs at present & am going to WT diffs as soon as I can get hold of some at a good price
Post Posted: Mon Jan 09, 2012 9:18 am
how long can you wait for rims? it could be easier to order what i got as my other set of rims, which is procomp series 52 in 15x7 -38mm... they were about $140ea or so delivered... although i did have an issue with 3 rims having valve holes in the wrong spot, these were replaced at a later date under warranty.
the original set of rims took over 3 months to arrive and the replacements a similar amount of time because theyre made to order in the USA and then boated over to victoria before being despatched by road!
Post Posted: Mon Jan 09, 2012 9:20 am
procomp do a 2" backspaced wheel thats about the same as a flipped rim
for around $150 ish a rim
Post Posted: Mon Jan 09, 2012 9:22 am
What's the turn circle like with that much offset Alien? Mine is crap already with speedy 8" -24 rims
Post Posted: Mon Jan 09, 2012 9:25 am
i can wait a little while, its not going to be back on the road for a while anyway but i paid $30 a rim for these, they are near new so I can still get em done and it not be too much of an expensive exercise.
the procomps were my first choice, but didnt want to have to wait three months for them, but if i had have ordered them when i first started they would have been here by now!!! :x
live n learn huh
like i said before i might try a few local engineering places to see if the can do it, might be cheaper, cant hurt to ask & i can repaint em afterwards, will let you guys know how i go
Post Posted: Mon Jan 09, 2012 9:29 am
it only gets worse by the amount you go wider... so mines like... 188mm worse than factory running 31x10.5's on the 15x7 -38... although with my stretched wheelbase its worse that that again, but yeah =)
edit: oh yeah, and a 15x8 -24 is almost identical width to a 15x7 -38...
Post Posted: Mon Jan 09, 2012 9:37 am
u measure the backspace from the edge of the rim down to the rear face of the rim yeah ? if so my flipped rims are -70
Post Posted: Mon Jan 09, 2012 9:53 am
-70 means its 70mm off the center line in the direction of the vehicle, so the outer edge is 70mm further out than if it was centered.
backspace is another measurement alltogether and way harder to use IMO.
edit:
Post Posted: Mon Jan 09, 2012 9:58 am
Rob has shut up shop from what i've last heard
Post Posted: Mon Jan 09, 2012 12:12 pm
really? wow, when did that happen? i know he had health issues but he told me he was all clear and good to go?
Post Posted: Mon Jan 09, 2012 9:38 pm
Expensive.
Pete their website says they closed in 2008, have they opened again or am I looking at the wrong ones.
Post Posted: Mon Jan 09, 2012 10:10 pm
2stroker wrote:
Expensive.
This Guy 8)
Users browsing this forum: No registered users and 107 guests
