It is currently Mon Oct 19, 2026 7:32 am
Post Posted: Sat Aug 09, 2008 2:55 am
Is there any other stock springs that are like 2 inch lift to a suzuki that will fit in?
Has any one got jeep springs in there suzuki
And what is the best sierra set up for 4x4?
Post Posted: Sat Aug 09, 2008 3:24 am
What do you want to acheive these stock springs that equal a 2 inch lift in your sierra? Cheap springs? Better ride? Better flex?
Jeep springs are a big job, they are wider so requires mods to spring hanger and missing link setups and or funky shackles. These set ups are way more common in the US because the springs are available.
The best setup depends on what you want to drive. If you just want to bush bash put a body lift or some cheap 2 inch springs in, get some bigger tyres and go for it.
If you want some more flex and better ride try RUF and a longer spring (mazda, isuzu) in the back with longer shackles to suit.
Search as much as you can and find out what is the best for you.
Post Posted: Sat Aug 09, 2008 3:36 am
springs are pretty cheap just get some from a good spring shop (arb or somewhere) and see Bruce he makes bushes he might have some good ones for you
if you get the springs reset they are a bit harder than new ones but it is a cheaper option
Post Posted: Sat Aug 09, 2008 4:15 am
i might get the stock springs prest up
and do 2 in the bl
on 30s
hello
Post Posted: Sat Aug 09, 2008 11:23 am
and do 2 in the bl
on 30s
Just for your info, if you get your standard springs reset for a two inch lift, they normally tend to sag again within a few months
Post Posted: Sat Aug 09, 2008 1:19 pm
thats true,once they are reset they sag really quick and for the price of 2" omes about 73 a side up front and 80 a pair on the rear its pretty cheap and they work well....Will give you about 40mm lift.....our local spring works wants 100 a corner nearly to reset them so omes are a better option?????
appsie
Post Posted: Sat Aug 09, 2008 1:23 pm
and do 2 in the bl
on 30s
If you're going to do a body lift dont worry about the springs. You will fit 30s under there with just a body lift and a little trimming.
Users browsing this forum: No registered users and 275 guests
