It is currently Fri Nov 06, 2026 7:31 pm
Post Posted: Sun Nov 06, 2011 10:00 am
Time to invest in a notcher. Seems to be alot of info on everything but notchers.
Would like to know what people are using and where did they get it from.
Looking to get something online because its usually cheaper than that of local equivalent up here in Darwin. Price is not an issue as it will be for future projects and have time to save.
Any push in the right direction would be great :)
Post Posted: Sun Nov 06, 2011 10:30 am
There is a program you can get that tells you what angles to cut using a drop saw that means you don't need a notcher
Post Posted: Sun Nov 06, 2011 10:37 am
I would try OPW which sell JD Squared equipment. Heres the link...
http://jd2.com.au/notchers/
Post Posted: Sun Nov 06, 2011 6:30 pm
i have used the speedworx one and OPW's JD2.
both give great results but the jd is a much tighter feel, just feels more solid, rigid.
http://www.speedwerx.com.au/products-de ... id=&pid=12
http://jd2.com.au/images/detailed/0/notchmaster-1.jpg
Post Posted: Sun Nov 06, 2011 10:52 pm
If im at work, I cut them with a bandsaw 2 45'ish angle cuts and grind the inside a touch.
If im at home, I cut the angles with a grinder..
Post Posted: Mon Nov 07, 2011 3:11 am
i used to do the same with the grinder. Took far too long with just the rear bar. I plan to build a buggy completely from tube, so i need a notcher.
Dropped jd squared an email regarding the 'notchmaster' one, hopefully they are reasonable on freight
Post Posted: Mon Nov 07, 2011 3:14 am
I'll rent it of ya Timmy :D. I to wish to build a buggy. Already have an r1 motor plus loom and ecu for the power.
Post Posted: Mon Nov 07, 2011 3:21 am
I have this one,
http://jd2.com.au/notchers/tn-100.html
works really well on thin wall moly tube.
Post Posted: Tue Nov 08, 2011 12:24 am
thanks again for the help guys, still waiting for an email back but sounds like people are generally happy with JD squared gear.
Post Posted: Wed Sep 12, 2012 11:00 am
bit of a grave dig.
obviously the JD2 stuff is great, but has anyone played with the cheeper ones?
Im looking at this
http://www.machineryhouse.com.au/P090
obviously its not going to be as good as the JD2, but for less than half the prices will it be good enough?
Im only looking at 8-10 notches
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Sep 12, 2012 11:13 pm
U could make one ;)
Post Posted: Wed Sep 12, 2012 11:24 pm
These guys have some cool stuff:
http://www.trick-tools.com/Tube_Notching_Endforming_145
Prices are good compared to local, but the only shipping quote I've got from them evened things out. Worth a look though.
Post Posted: Thu Sep 13, 2012 4:23 am
I like just to buy the mourse taper shank and hole saw u could easly make the rest
Post Posted: Thu Sep 13, 2012 8:44 am
KEENSY85 wrote:
U could make one ;)
by the time ive bought the parts i need for it and made one i may as well have bought a good one $$$ Vs time
Users browsing this forum: Google [Bot] and 80 guests
