It is currently Sun Nov 08, 2026 7:13 pm
Vehicle: SV420 SE416SWB SE416LWB SIERRA
Post Posted: Fri Dec 09, 2011 5:03 am
im about to buy my first 2L vitara, i want a 2"-3" lift not a cheesy 30mm like most companies offer. after talking to calmini they cant varify if their products works on a 2L as all designs were done on a 1.6
if any one know anything that would be a big help...
atari im lookin at your help on this one :helloo:
Post Posted: Fri Dec 09, 2011 5:11 am
:helloo: i'm currently dealing with a headfuck of a job... please hold. :oops:
Post Posted: Fri Dec 09, 2011 5:36 am
what lift have you done to your 2L as it looks to be alot more fun than a lift the width of a finger nail? do you know if the solid axle swap works? what is different on the 1.6 to the 2L?
Post Posted: Fri Dec 09, 2011 5:54 am
there are a few differences, mainly the width of the chassis rails. i'll try & knock something up with a bit of detail later tonight after i've put out this fire...
Post Posted: Fri Dec 09, 2011 6:07 am
:youdaman:
Post Posted: Fri Dec 09, 2011 11:57 am
You'd think by now that Calmini would know that their kit doesn't bolt into the SV420/620 "Sports" series of Vitara's but, no apparently not... :roll: (Mr Calmini I'm looking at you)
It doesn't not "bolt in". The chassis rails are further apart than the SE416 (1.6), the rear all bolts in as per normal but the front is what causes issues. The diff drop brackets need to be modded to suit (60mm each side from memory) & the cross member needs to be clearanced to allow for the diff drop & maybe some of the strengthening webbing off the bottom of the alloy diff. Have a look thru Stuey's & my build thread for pics of the diff drop brackets & crossmember chop.
To counter he extra weight of the motor I am running the 2.5" GV calmini springs. You will also need to buy a pair of ball joints to suit the SE416 as they are part of the control arm on the SV's. The swaybar doesn't fit as it bolts to a different position compared to the sway bar bolt holes on the Calmini arms, SE swaybar bolts in. I haven't run a swaybar for 6 years!
Then there is all the other odd things like front bars, brakes, fuel tank etc...
let me know if you need any more info. :wink:
Post Posted: Tue Dec 20, 2011 12:47 am
What snorkle have you got on yours atari? i have checked all my suppliers through work and they only list 1.6 items.
Post Posted: Tue Dec 20, 2011 12:58 am
i'm running the fiberglass FTS one from ODA but there is an airflow one which is a normal plastic material, i would prefer the plastic one but i don't like the shape of it running down the guard. http://www.ebay.com.au/itm/Airflow-Snor ... 2a163428df
Post Posted: Wed Feb 08, 2012 8:53 am
Anyone know the diff centre count on a 2L shorty? also what diff centre works best on these for 31" tyres?
Post Posted: Wed Feb 08, 2012 9:05 am
5.12's will bring it back to stock on 31's & they're a 26 spline front.
Post Posted: Wed Feb 08, 2012 9:27 am
5.12 came out in the 1.6 LWB? yeah?
Post Posted: Wed Feb 08, 2012 9:35 am
all manual vit's & 4 speed auto's have the 5.12's, the early ones will be a 22 spline center
Post Posted: Wed Feb 08, 2012 10:11 am
not sure if this is a Domestic market only situation, but EVERY auto 1.6 vitara front cut I have imported from the motherland ( atleast 6) has been 4.6:1 ratio.
Post Posted: Wed Feb 08, 2012 10:18 am
really?
cause i know Polar_Bears auto front cut had 5.12's & i also know that nicbeer's front cut also had a 5.12 front & to quote the factual G-banger...
viewtopic.php?f=5&t=29770&hilit=3+speed+auto
All manuals: 5.12:1
Auto (3 speed, G16A Carby) 4.6:1
Auto (4 speed, G16B 16V) 5.12:1
but not sure if that was just for our local market or not. :?
Post Posted: Wed Feb 08, 2012 10:20 am
really?
http://www.auszookers.com/forum/viewtop ... speed+auto
All manuals: 5.12:1
Who knows. But the R&P's that were in my ute for 12 months were both from my auto frontcuts ex-japan...... 4.6:1. I still have a few more sitting around. They also ALL had auto hubs.
Post Posted: Wed Feb 08, 2012 10:29 am
both of those diffs from the front cuts have spent quite a bit time in the front of mine with a 5.12 rear & both front cuts had auto hubs.
were they 22 or 26 splines, as the two 5.12's were 22's, just thinking that the last of the auto Escudo's might have been 4.6:1 & 26 spline.
Post Posted: Wed Feb 08, 2012 10:33 am
Can't remember Gus. I junked everything except the R&P's. I see what I have left. At one point I had so many I just chucked them out. :?
Post Posted: Wed Feb 08, 2012 10:54 am
do you remember what shape dashboard did the front cuts have,?
Post Posted: Wed Feb 08, 2012 12:04 pm
2 were X-90's, so same as ours. Atleast 2 were 94-95 SWB ( late model vit dash ) and the rest I don't recall.
Post Posted: Wed Feb 08, 2012 12:26 pm
x-90's aren't real Vitara's so they don't count :lol:
Post Posted: Wed Feb 08, 2012 12:57 pm
They look the same when the body is missing :wink:
Users browsing this forum: No registered users and 111 guests
