Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
Posted: Mon Dec 12, 2011 5:17 am
There has been alot of talk about using a commadore shock in the rear of a Vitara but what about the GV? How much longer is the commadore shock over a stock Vitara shock? The GV shock is almost the same as the Vit but the valving is suposed to be different as its a bigger, heavier car.
Joined: Sat Aug 12, 2006 11:30 pm Posts: 6456 Location: Radelaide ofcourse!
Posted: Mon Dec 12, 2011 5:30 am
I put some camira shocks in the rear of mine, but i dont have as much lift as you. I tried the VL commo rears i have sitting in my vit lwb with the calmini but they were just way too long.
I reckon they would be closer to what you need, i could measure one for you tomorrow as i have one out sitting in the back of the lwb at my stepdads.
Joined: Fri Oct 23, 2009 10:30 pm Posts: 257 Location: Brisbane North
Vehicle: 02 GV
Posted: Mon Dec 12, 2011 6:05 am
I used vt wagon shocks, about 59cm's long extended so I have 75mm's of lift. works perfect, actually 20mm longer would be better and no springs falling out (been there done that) with the sedan shocks that are 66cm's long.
Users browsing this forum: Google [Bot] and 94 guests
