Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Fri Dec 16, 2011 12:35 am |
Can any one tell me what size the seals are from a 1.3 WT transfer? i need to get some and dont really want to wait until i can get them in a kit from low range.
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Fri Dec 16, 2011 2:39 am |
go to cbc they have a list of all the seals
_________________ Camels have nice toes
weaves
Joined: Fri Mar 21, 2008 10:30 pm Posts: 1564 Location: Newcastle
 Posted: Fri Dec 16, 2011 3:55 am |
_________________ I'm Weaver & i like beer, boobs, cars and stickers
BlueSuzy
 Posted: Fri Dec 16, 2011 3:58 am |
2x 38 60 8mmthk
1x 38 50 8mmthk
Speedo insert gear seals:
1x pushes into a 16.2mm hole, seals on a 7.9mm shaft. So allow smaller hole and bigger outer for a nice seal. Unsure width, 5mm By the looks of it.
Oring around speedo insert, must seal on 19mm shaft, o'ring is 1.9thk, but slot is 2.4mm wide.
BlueSuzy
 Posted: Mon Dec 19, 2011 3:20 am |
Would these seals be ok for sealing on a 39.9 shaft? Seems i have some Wt pattern flanges here, but sizes are different?? The jackshaft and front output flange is taller so you cant get the spline nut on.. By 11.6mm..would these be coily? Using a 88.5wt casebut originally use nt shafts... Looks like i need to machine these weirdo's to make a normal wt flange...
BlueSuzy
 Posted: Mon Dec 19, 2011 3:22 am |
the rear output fit straght on. Thought it felt bit tight in seal..
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 126 guests
