It is currently Sun Nov 08, 2026 4:25 am
Post Posted: Fri Dec 16, 2011 12:35 am
Can any one tell me what size the seals are from a 1.3 WT transfer? i need to get some and dont really want to wait until i can get them in a kit from low range.
Vehicle: LJ20 LJ50
Post Posted: Fri Dec 16, 2011 2:39 am
go to cbc they have a list of all the seals
Camels have nice toes
Post Posted: Fri Dec 16, 2011 3:55 am
Post Posted: Fri Dec 16, 2011 3:58 am
2x 38 60 8mmthk
1x 38 50 8mmthk
Speedo insert gear seals:
1x pushes into a 16.2mm hole, seals on a 7.9mm shaft. So allow smaller hole and bigger outer for a nice seal. Unsure width, 5mm By the looks of it.
Oring around speedo insert, must seal on 19mm shaft, o'ring is 1.9thk, but slot is 2.4mm wide.
Post Posted: Mon Dec 19, 2011 3:20 am
Would these seals be ok for sealing on a 39.9 shaft? Seems i have some Wt pattern flanges here, but sizes are different?? The jackshaft and front output flange is taller so you cant get the spline nut on.. By 11.6mm..would these be coily? Using a 88.5wt casebut originally use nt shafts... Looks like i need to machine these weirdo's to make a normal wt flange...
Post Posted: Mon Dec 19, 2011 3:22 am
the rear output fit straght on. Thought it felt bit tight in seal..
Users browsing this forum: No registered users and 117 guests
