It is currently Sun Nov 08, 2026 6:58 am
Post Posted: Mon Dec 19, 2011 8:51 pm
Does anyone know of a 2speed gear box/tcase that has a 1:1ratio and 1:1.5-1:2ratio? and maybe a neutral?
Thanks :D
Post Posted: Mon Dec 19, 2011 8:57 pm
Ski boat V drive box maybe...
Lots of step up ratios available.
http://www.cassellmarine.com.au/p/32402 ... drive.html
Post Posted: Mon Dec 19, 2011 9:12 pm
needs to be a straight through design, that looks like it returns....
Post Posted: Mon Dec 19, 2011 9:16 pm
It does have input and output on one side but I'm sure it could be modified to be suitable.
Just an idea anyway.
Post Posted: Mon Dec 19, 2011 9:20 pm
thanks jas, i don't think i want to spend $1800 to modify it.....
a vit with a chopped off output might be my best option so far...
Vitara, High: 1.00, Low: 1.907
edit: it's the under drive idea used in the rc world that im trying to achieve. We put a higher pinion in the front and lower pinion in the rear to get the front to pull up steep inclines and to kinda suck it's self onto the rock face.
much like how Pete (opw) use to have an air operated rear disconnect that he would just tap the button on steep inclines to keep the rear from driving under itself. But this way it will be a constant drive, not intermittent drive.
Post Posted: Mon Dec 19, 2011 9:37 pm
Buy a 3 speed atlas case 8)
Post Posted: Mon Dec 19, 2011 9:49 pm
will it do that?
Post Posted: Mon Dec 19, 2011 10:18 pm
plus front and rear disconnect! 8)
Vehicle: '96 LWB trayback
Post Posted: Mon Dec 19, 2011 10:41 pm
I've got a vit transfer at my place you can have if you want to hack it up as part of your experiment.
Post Posted: Mon Dec 19, 2011 11:53 pm
yeah so do i.... thanks mark.
Post Posted: Tue Dec 20, 2011 12:01 am
Not sure on the ratio's, But the datsun 720's have a divorced transfer
http://www.auszookers.com/index.php?nam ... 65&start=0
Post Posted: Tue Dec 20, 2011 12:07 am
from my research, your telling me to buy a coily that isn't gay? i can only find a 2 and 4 speedcase....
1:1 high 2.07:1 low.
Post Posted: Tue Dec 20, 2011 12:12 am
get a planetary set out of an auto and machine and weld and hammer some stuff up, will give direct drive and a choice of 2 ratios with one gearset
Post Posted: Tue Dec 20, 2011 12:40 am
hmmm, i've got the hammer sorted..... i know nothing about auto's tho.... sounds allot like a vit case is the closest thing out there....
Post Posted: Tue Dec 20, 2011 4:40 am
if you doing 1 you might as well do one for me as well :D
Post Posted: Tue Dec 20, 2011 8:04 pm
I believe , but can't proove,
that early 4wd's had a very slightly higher front diff ratio,
for that reason, and for safer descents.
Was told this as a kid, so could be BS,
but does make sense for a p/t 4wd.
Post Posted: Wed Dec 21, 2011 2:36 pm
yeah, i chucked up this on ZK and a few guys were thinking the same thing... maybe 3.7-3.9 ratio and only used 4wd off road....
http://www.zukikrawlers.com/showthread.php?t=44794
Users browsing this forum: No registered users and 129 guests
