It is currently Sun Nov 08, 2026 4:22 pm
Post Posted: Sun Jan 08, 2012 11:32 pm
How illegal in Queensland is it to remove the mud flaps off my zook?
Will this cause any issues?
Thanks
Post Posted: Sun Jan 08, 2012 11:35 pm
Mudflaps in NSW have to cover the full tyre and be maximum 300mm off the ground.
I drove with no mudflaps for 3 years.
All depends on your luck.
Vehicle: '94 suzuki maruti
its illegal, but whenever you get pulled up you can sometimes get away with saying it was like that from new. unless the cop knows sierras, it works... well, did for me anyway.
Post Posted: Sun Jan 08, 2012 11:37 pm
I don't know about Queensland, but it is the #1 cause of cars being defected in Victoria.
Why would you want to take them off? I know there are good reasons to remove them off road, and many of us do, but we always put them back on when we air up. Throwing stones at following cars is not cool.
I run hooks on mine so I hook them up out the way when I am in the bush.
Post Posted: Sun Jan 08, 2012 11:40 pm
Cheers for the quick replies fellas
Yeh I will leave them on I suppose I wouldn't want to chip cars behind me
Post Posted: Mon Jan 09, 2012 12:00 am
the biggest issue i have with my mudflaps is reversing over them, which tears the mudflap off the bolts that holds them in and destroys them... since going through a few mudflaps i've started cable tieing them on - now when i reverse over them the cable tie snaps and no the mudflap. Its usually loud enough that you hear it ping off and can collect the mudflap off the ground later =)
Post Posted: Mon Jan 09, 2012 10:12 am
I made quick release pins to take mine off when in the bush and pin back on for the street. This was after a visit to the pits for full inspection due to no flaps
Post Posted: Mon Jan 09, 2012 12:15 pm
anybody got some pics of non-moulded mud flaps on the vitara? i have found it hard to do, especially a 31" there is not enough room between the rear of the guard and the tire let alone have a mud flap there. mine are 100mm from the rear of the tire (on edge of bumper), it just doesnt look right.
Post Posted: Mon Jan 09, 2012 12:31 pm
Page 1 of my build thread has some more pics 8O
Post Posted: Mon Jan 09, 2012 12:45 pm
aww look at ya purdy back flaps =)
Post Posted: Mon Jan 09, 2012 12:49 pm
It was still new back then :(
They were adjustable, so you could tuck them up, but one got ripped off by polar bear cause I hadn't pulled them up. Was all done with nylon webbing tie down straps, now they're heaps shorter...
none of them show it well, but i dont think i have that much room. i have about 3mm between tyre and bumper bracket. the head of the bolt that held on the old flaps was rubbing on the tire lol. yours being higher would mean that the same bolt is near the top of the tyre not in the middle like mine.
Post Posted: Mon Jan 09, 2012 12:57 pm
Mine is a heap lower from that pic... that was with 3" BL. that bolt, I replaced with a dome headed one & it still rubs. The flap picks up all the original mud flap holes & was 5 or 6mm rubber.
Post Posted: Mon Jan 09, 2012 1:19 pm
pompoms
I dont think you'll ever let me forget that :oops:
Go Hard, Trailer Home
Post Posted: Mon Jan 09, 2012 6:24 pm
you can buy quick disconnects for your flaps these days ;)... no pun intended. you can get them from Low Range :)
Happy flapping ;)
Stocker
Post Posted: Tue Jan 10, 2012 6:48 am
Cut the front of the bumper back a bit and hit the plate back a bit then bolt the flap over the top
That's what I did till I got sick of hitting my bumper on everything and cut the whole thing off then just put nutcert in the back of the body and bolt them in their Image Image
Users browsing this forum: Google [Bot] and 78 guests
