It is currently Sun Nov 08, 2026 7:45 pm
Post Posted: Sun Dec 25, 2011 11:59 am
hi i got a mk2 engine i think :roll: anywayi put the mazda dizzy cap n rotor on and a w022a thermostat housing and the thermostat housing is almost touching the dizzy cap like the thermostat housing pipe needs to be a bit lower what can i try ?? maybe another thermostat housing??
Post Posted: Sun Dec 25, 2011 7:59 pm
You can use the thermostat housing off a suzuki swift cino (94-late90s i believe)
Post Posted: Mon Dec 26, 2011 2:19 am
anyone else or has anyone got a part number or something i tried supercheap and repco
Vehicle: SJ51T
Post Posted: Mon Dec 26, 2011 2:33 am
Go to a wrecker. I paid $11 for a swift one.
Theres a thread somewhere on here that tells you the part number if you want it that bad.
Post Posted: Mon Dec 26, 2011 2:36 am
I use swift ones. the top coolent pipe needs to run over your exaust.
Post Posted: Mon Dec 26, 2011 9:30 am
im using a 1.3 sierra thermostat housing
Post Posted: Mon Dec 26, 2011 9:49 am
Post Posted: Mon Dec 26, 2011 9:54 am
what is that 1 for
Post Posted: Mon Dec 26, 2011 10:19 am
red writing to the left of the 1 says:
Quantity
(quantitie)
Post Posted: Mon Dec 26, 2011 11:14 am
your trying to use the wrong part.
Post Posted: Mon Dec 26, 2011 11:15 am
post up a pic of your motor mate
Post Posted: Mon Dec 26, 2011 10:41 pm
pics
Post Posted: Mon Dec 26, 2011 10:45 pm
wrong thermistat housing, pointing the wrong way ;) yep that's a mk2/3
1st pic is engine
2nd is with the w022a thermostat housing
and the 3rd is with the sierra thermostat housing
Post Posted: Tue Dec 27, 2011 1:10 am
does it matter what way it goes
Post Posted: Tue Dec 27, 2011 1:13 am
yep. I have fucked around with gti cooling a lot..
best method is use a swift thermistat housing and direct it over the top of the exaust. I make and sell a stainless top hose that works perfect.
Post Posted: Tue Dec 27, 2011 1:24 am
would this work aswell with the Baleno motor i may be interested in the stainless top hose
thanks matt
Post Posted: Tue Dec 27, 2011 1:54 am
do u have a pic of it on motor and what does it matter if it goes over exhaust manifold or under intake manifold well i thought intake side would be a bit cooler
Post Posted: Tue Dec 27, 2011 2:02 am
if u go under intake you will get airlock issues..
Posibly belino, however hard to make without car.
Post Posted: Tue Dec 27, 2011 2:08 am
Users browsing this forum: No registered users and 101 guests
