It is currently Thu Aug 06, 2026 8:11 am
Vehicle: 89 swb vit
Post Posted: Thu Dec 29, 2011 12:10 am
Just put a fresh 16b motor into a vitara that previously had a 16a motor. Used all wiring harness from the 16b and motor fired up on second crank.
Motor appears to rev very hard on start without accelaration at approx 2000rpm then drops to between a 1-1200 rpm briefly before hunting between 2000 and 1000 rpm. Sounds like its being given a bit of throttle but doesnt settle after a minute or so.
I would appreciate any help or pointers on what to look for ar what may require adjusting to settle this down.
Thanks in advance!
Post Posted: Thu Dec 29, 2011 12:25 am
Bleed/remove air from cooling system. If this fails, check TPS and AFM.
Vehicle: 89 swb vit
Post Posted: Thu Dec 29, 2011 3:40 am
Thanks Zukmeister... I didnt think water or lack of bleeding it would cause the revving but will check anyway...
Is there any easy to do checks i can carry out without all the diagnostic tools to determine if there are issues with the AFM and TPS are these adjustable or repairable items?
Any other ideas on what the problem may be
Post Posted: Thu Dec 29, 2011 4:45 am
Try a vacuum leak I had a problem on my ok'd car like that wasn't a Zook but it ended up being a vacuum leak witch made it constantly search for a idle and sometimes made it stall hope it helps and good luck with the repair
Users browsing this forum: No registered users and 429 guests
