It is currently Sun Nov 08, 2026 12:28 pm
Vehicle: SJ70 1993
Post Posted: Tue Feb 14, 2012 7:24 pm
Hey guys, im thinking of running 35s and i need to put in appropiate gears in the diffs. With ratios higher the number slower/lower the gears are? I want to keep original zuk difs
Lock, Drop and roll
Post Posted: Tue Feb 14, 2012 7:27 pm
5.38:1 or 2 Vitara 5.12:1 fronts
http://www.lowrangeoffroad.com/index.ph ... gears.html
Vehicle: SJ70 1993
Post Posted: Tue Feb 14, 2012 7:33 pm
Yeah i was looking at low range but wasnt so sure what i was after cheers
Lock, Drop and roll
Post Posted: Tue Feb 14, 2012 8:15 pm
You'll want transfer gearing as well if you drive anything steep.
Whilst 5.12's alone will correct 35's on road, gearing off road will be terrible. Even though it's effectively the same as with stock tyres, the added weight and traction of the 35's will kill clutches and be scary on hills, even more so with lockers.
Vehicle: SJ70 1993
Post Posted: Tue Feb 14, 2012 8:19 pm
I all ready got ultra slow rock crawlers in the transfer, cheers thou :)
Lock, Drop and roll
Post Posted: Tue Feb 14, 2012 8:20 pm
what ratio?
Post Posted: Tue Feb 14, 2012 8:23 pm
i plan on running 35s and will have 4 speed auto, 4.88 diffs and 6.5 transfer gears
should be a good thing
Vehicle: SJ70 1993
Post Posted: Tue Feb 14, 2012 8:33 pm
Yep same as what i want shep, maybe even lower diff ratio
Lock, Drop and roll
Post Posted: Wed Feb 15, 2012 6:51 am
Good work explaining that in your first post...
Post Posted: Wed Feb 15, 2012 7:44 am
Where in the hunter will this be driven?
Post Posted: Wed Feb 15, 2012 12:32 pm
if your running 35's stock gbox and with transfer 6.5's. 4.88 is ok i guess. it will be screaming at 100km/h though.
Another guy on here has the same setup, with lux diffs, he has 4.55's.
I'm going to test with same setup, 4.3 with lux diffs. High revs chews petrol, and is noisy and bad for the motor. Trying to get the motor about normal revs for a sierra
Post Posted: Wed Feb 15, 2012 12:43 pm
Depends on what you constitute for high revs. Ideally you want to rpm to be high enough that you are producing enough torque to counteract the wind and rolling resistance at the highest volumetric efficiency possible. This should give you the best fuel economy/resistance figure. Around 3.5-4k seems pretty good for the G16b.
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Wed Feb 15, 2012 1:16 pm
mine works out at 3634rpm at 100kph :wink:
Post Posted: Wed Feb 15, 2012 2:16 pm
With or without afterburners on :lol: :hey:
Post Posted: Thu Feb 16, 2012 8:52 am
Thats the revs im aiming at. Unsure what the other guy is aiming for.
Shep you have an auto..Not same ratios as mine. :P
Post Posted: Thu Feb 16, 2012 10:44 am
Plus my car is awesome
Vehicle: SJ70 1993
Post Posted: Fri Feb 17, 2012 10:13 am
Anywhere and everywhere
Lock, Drop and roll
Post Posted: Fri Feb 17, 2012 11:05 am
Anywhere 35's would be any help is going to break the driveline in some way.
May want to consider some custom zook bits.
Users browsing this forum: Google [Bot] and 56 guests
