However, where did the oil go? What have you done to stop the new oil falling out? What oil are you going to put back in? How much of it?
Steering boxes are not "serviceable" items - it might be possible to pull them apart and replace the seals, but there aren't replacement hard parts available AFAIK, so if the seals failed due to wear in a bush/shaft new seals won't help.
I have refilled boxes with oil in the past but it's only a band aid before you're looking for a replacement.
PS the actual procedure for setting the adjustment screw is a bit complex - it has to be done with the steering shaft (and drag link) off the box and is set by drag on the input shaft. I now we all "suck it and see" but I actually think the required drag on the box is MUCH higher than anyone thinks. I reckon this is a big contributor to death wobbles.
Users browsing this forum: No registered users and 156 guests
