It is currently Sun Nov 08, 2026 6:10 am
Post Posted: Fri Mar 23, 2012 5:25 pm
Hiya all,
I'm servicing my wife's Mirage brakes and am curious as to what type/brand of grease is recommended for the brake caliper pin and the back of the pad? On the back of the old pad there's copper grease but the caliper pin is looking rather dry.
In my GV there's no requirement for grease on either the pin or pad so am not sure what to use.
Thanks,
Ben
2002 SWB GV
Lifted and Locked
Post Posted: Fri Mar 23, 2012 6:54 pm
All caliper pins need grease. I usually use a moly grease
Post Posted: Sat Mar 24, 2012 4:18 am
I use Permatex Ultra Disc Brake Caliper Lube synthetic lube on the slide pins
and Permatex Disc Brake Quiet on the back of the pads
The disc brake quiet is also available in a two pouch blister pack that's enough to do both calipers if you don't want to buy a can.
Vehicle: 1999 Jimny
Post Posted: Sat Mar 24, 2012 6:39 am
Be careful because Scrawn uses grease on the front of his pads too :shocked: ......bahahahaha.
Post Posted: Sat Mar 24, 2012 8:23 am
Brakes only slow you down :roll:
Post Posted: Sat Mar 24, 2012 11:35 am
I was about to buy the green permatex brake lube but I've read a few reviews about it swelling some rubbers in contact with the caliper pin. Mostly with Mitsu's and Toyotas. I was going to try the CRC equivalent as there's less reported problems.
Has anyone used the CRC products with success?
Was going to use copper grease on the rear of the pads.
2002 SWB GV
Lifted and Locked
Post Posted: Sat Mar 24, 2012 11:40 am
Let's just say in five years I've had no problems - package says it's safe for use on rubber.
Post Posted: Sat Mar 24, 2012 1:27 pm
What other cars have you used them on? Any Mitsu's or Toyotas?
2002 SWB GV
Lifted and Locked
Post Posted: Sat Mar 24, 2012 1:49 pm
i use a smear of castrol rubber grease (red) on the caliper pins
Post Posted: Sun Mar 25, 2012 2:49 am
Yup & yup - a Pajero & a Corolla.
Users browsing this forum: Google [Bot] and 111 guests
