It is currently Mon Nov 09, 2026 5:50 am
Post Posted: Thu Mar 29, 2012 3:11 pm
Last weekend I camped a stockton beach for a night, on the way home I noticed a clicking noise coming from under the car. It only start when the car is actually moving and sometimes stops when the car is just coasting. I wriggled the drive shafts and cv's to see if and joints were broken but all seems good. Only other thing I can think of is maybe the diffs.
Any suggestion would be greatly appreciated
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Mar 29, 2012 3:44 pm
Are you sure it's coming from under the car and not anywhere else?
Could be anything really? Can you explain what it sounds like in a bit more detail?
I had cars making clunking noises and it was the engine mounts flogged out... after driving up stocko and bouncing around it may have finished yours off.....thats a pretty big maybe though?
Post Posted: Thu Mar 29, 2012 4:10 pm
If there is any movement in your UNI's then, grease em up/replace them. Also look for movement in your slip joints in your tail shaft.
Drain your Gbox, Transfer and diffs, then refill with VMX-80, or the EPX90 I left behind my car :lol:
While draining your oil's you can see if there is any chuck of steel, or fillings. You can, with a good torch and eye see the teeth on the diff see if any look damaged, but your probs going to see diff parts come out with oil before you see missing teeth haha.
Also, I think there is a 5speed Vit box and transfer case behind my tool chest. There yours if you want them.
Post Posted: Thu Mar 29, 2012 4:13 pm
:lol:
"hey do you know if anyone has a vitara gearbox?"
"yeah, behind the cupboard"
Post Posted: Thu Mar 29, 2012 4:17 pm
joshy it's a vit.... there will be no grease nipples (unless it's got aftermarket uni joints) or a slip joint (will have a slip yoke on the transfer case end)
does it still make the noise in 2wd?
it could be a dry uni joint or a missing tooth in the diff or wheel bearings.
does the noise match the road speed?
Post Posted: Thu Mar 29, 2012 4:39 pm
My front diff made a banging noise when it went. I took out 4 teeth, so maybe you only did a couple and its going click click.
(P.s. Wayne murphy in his old zook on the TT2011 dvd just started getting a clicking noise from his diff haha.)
Post Posted: Fri Mar 30, 2012 5:02 am
Cheers josh im hoping its not something to do with the transfer
Atari, sure does makes the noise in two wheel drive and also matches the speed im doing.
ill grease the unis and hope for the best.
Users browsing this forum: No registered users and 87 guests
