| Author |
Message |
sj70zuki
Joined: Sun Jan 08, 2012 10:01 am Posts: 89 Location: Childers QLD
Vehicle: sierra sj70 1993
 Posted: Sun Apr 01, 2012 4:26 pm |
will a 4000lbs winch be enough to pull my sierra out of a bog hole??
_________________ dont get mad get muddy
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Sun Apr 01, 2012 4:30 pm |
Depends. Some "bogholes" are worse than others.
I'd go with a 6000-9000lb winch so you don't wish you hadn't have gone with the 4000lb winch when its not up to the job.
_________________ mlm
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Sun Apr 01, 2012 4:46 pm |
X2.
I'd say 6000lb is the minimum. Part of the problem with winches under 6000lb is they tend to have poor brakes and don't run suitable cable/rope for vehicle recovery - they might be fine for pulling an ATV onto a trailer or something, but I'm not sure I'd leave my car hanging on it.
6K winches are cheap enough now I'd see no reason to buy a 4K winch.
Bog holes can be terribly hard on winches - it's not always clear how hard you are caught up, if a tyre is trapped under a tree root etc.
ZookFan
Joined: Mon Feb 14, 2011 6:19 am Posts: 3978 Location: Brisbane,samford,QLD
 Posted: Sun Apr 01, 2012 8:27 pm |
Good point there mate
ridzilla
Joined: Mon Sep 26, 2011 11:27 am Posts: 306 Location: Western Australia
Vehicle: '91 Sierra, Fluffy Dice.
 Posted: Sun Apr 01, 2012 10:54 pm |
I've got a 4K winch, haven't had a problem with it so far
_________________ If at first you don't succeed, get a bigger hammer
Gwagensteve
 Posted: Mon Apr 02, 2012 7:41 am |
I've seen the brakes on some cheap 6k winches fail to hold a car on a climb. I can't describe how scary this is when the consequences of brake failure is the car doing a multiple rollover. I'd never given any thought to the quality of a winches brake before I saw that, but it made me very suspicious of cheap winches and low winch ratings.
Ultimately, the winch is there as the last option when all other options are exhausted, and it generally means you're out there by yourself, because if there were other cars/people around it's unlikely you'd need to winch. As such, winches need to be viewed as safety equipment.
Sure, if all you are ever going to winch out of is a flat bog hole, then maybe a 4K winch, through a snatch block, will do the trick, but if you had the car in a dangerous position, or near the top of a long multiple pull hill, I'm not sure I'd trust a 4K winch.
In any case, 4K is under the limit for the recommended minimum size for a sierra.
A Sierra's GVM is typically 1350kg. The rule of thumb for winch sizing is GVM X 1.5 so 1350 X 1.5 = 2025kg That's to take into account the car might present more than its GVM worth of drag - if a tyre is trapped under a tree root, the car has suctioned into mud etc. 2025kg converted to lb = 4400lb
Most people would say that if the car was right at the recommended limit, you'd upsize to the next size up (so, 6K) but nobody would ever recommend downsizing to under the GVM X 1.5 figure.
thesupervisor
Joined: Sat Jul 30, 2011 12:14 am Posts: 193 Location: perth
 Posted: Mon Apr 02, 2012 10:33 am |
so any recomondations for a 6000 to 10000 lb winch ? and price
Scales
Joined: Mon May 30, 2011 9:28 am Posts: 2233 Location: Townsville
 Posted: Mon Apr 02, 2012 3:25 pm |
i got a magnum 9k which is pretty badass. only used it a few times but works good. bit slower than its bigger brother warns but i like it.
atari4x4
 Posted: Mon Apr 02, 2012 5:12 pm |
thesupervisor wrote: so any recomondations for a 6000 to 10000 lb winch ? and price PM Dank aka KPD4x4 in the business directory
squibby
Joined: Wed May 11, 2011 3:13 am Posts: 645 Location: Brisbane
Vehicle: On the lookout
 Posted: Mon Apr 02, 2012 6:19 pm |
thesupervisor wrote: so any recomondations for a 6000 to 10000 lb winch ? and price Tigerz 11 are on offer I think at the moment. Not sure I'd recommend one at the RRP, but on sale it's probably a good deal. They do a 6000lbs. You can buy a block and double up to get effectivly 12000lbs of pulling power from a 6000lbs, but it's a compromise, and you should probably buy more rope if you do that or it'll be too short.
_________________ Crispy old grand vitara
GRPABT1
Joined: Mon Nov 19, 2007 10:30 pm Posts: 731 Location: Townsville
 Posted: Mon Apr 02, 2012 8:13 pm |
Haven't had a drama with my Tmax 6500lb winch so I would reccomend that.
