It is currently Sun Nov 08, 2026 3:43 am
Vehicle: 85.Ruf. rear air locker
Post Posted: Thu Apr 05, 2012 6:41 pm
Is it possible to get a vitara carby on a Sierra to idle low ???
Post Posted: Fri Apr 06, 2012 1:03 pm
Wouldn't it be a simple idle speed screw adjustment ?
Can't see why it would be hard.
Post Posted: Fri Apr 06, 2012 1:22 pm
The idle speed screw is wound all the way out
Post Posted: Fri Apr 06, 2012 1:26 pm
Check your throtel cable and make sure you have the wiring the right way around hope it helps
Post Posted: Fri Apr 06, 2012 1:28 pm
ok, not being silly, but is the throttle cable holding up the revs, have you moved the butterfly fully shut to see ?
I put a vitara carb on a mates sierra for him, and all that was needed was to idle down a touch, and jet down a bit, as it was rich as, but idle was just the screw.
Post Posted: Fri Apr 06, 2012 1:33 pm
Nope cable isn't tight
Any other ideas
Post Posted: Fri Apr 06, 2012 1:37 pm
Have you pulled the top off n looked down the throat, see if the choke is on, really doesn't take much to make it rev, physically touch the butterfly, see if it moves more to the upright position.
Post Posted: Fri Apr 06, 2012 1:39 pm
Other than that, I have little ideas, maybe the idle up actuator is holding revs up, turn on the lights, see if it revs up further, if not, its the actuator stuck on.
Post Posted: Fri Apr 06, 2012 1:42 pm
I'll try all that and see if anything happens
Post Posted: Fri Apr 06, 2012 2:16 pm
Check the choke?
Post Posted: Fri Apr 06, 2012 11:49 pm
Was the choke :)
Post Posted: Sat Apr 07, 2012 6:13 am
Vacuum leak ?
Post Posted: Sat Apr 07, 2012 8:02 am
Happy ending, cooooool.
Users browsing this forum: No registered users and 132 guests
