It is currently Sun Nov 08, 2026 1:55 am
Post Posted: Sat Apr 07, 2012 9:01 am
Hi all,
In the middle of trying to install my dobinsons lift and Im having trouble removing the nut on top of the front struts. whats the best way to go about it?
I removed the whole strut from the car and then put it all back together because i thought it would be impossible to take off whilst out of the car. so after i put it all bacvk together, wheels on, car on ground as per normal, i had another crack but it still twists with the rubber when i apply force to undo it.
hope you can help,
Mark.
Post Posted: Sat Apr 07, 2012 9:16 am
A rattle gun usually spins them off.
In rare cases you may have to clamp the shaft with vise grips or similar. This is a last resort as it does damage the strut insert.
Post Posted: Sat Apr 07, 2012 9:24 am
just tried clamping it with vise grips and some rubber for grip, no worky.
ill bust out the rattle gun, hope it works otherwise ill have to pay someone to put the lift in. ghey.
thanks want33's.
Post Posted: Sat Apr 07, 2012 9:27 am
Are there two nuts locked together? I've always just rattled them off no problems
Post Posted: Sat Apr 07, 2012 10:17 am
Unless someone's done something odd to them before now it'll be one nut, but it'll be good and seized. I trashed a mount trying to get mine off the first time.
I take it there's no thread showing through the top of the nut so you can't get a shifter onto the squared section at the top?
Usual tricks like soaking with WD-40 or Inox for a few hours will help, a few cycles of heating and cooling might make a difference (didn't for mine, but you never know...) or targetted application of a BFH might shake things loose.
As a last resort I ended up having to put a cutting disc down through the shaft and cutting the nut in half, and still had to hammer the fragments off. If you're not keeping the old struts it doesn't matter if they get destroyed in the process.
Post Posted: Sat Apr 07, 2012 10:49 am
Soak it In a tub of diesel over night should come off after that
Post Posted: Sat Apr 07, 2012 10:54 am
It's quite common to find two nuts locked together on top of shocks, stops them coming undone. Nyloc nuts are also used
Post Posted: Sat Apr 07, 2012 12:08 pm
rattle gun worked a treat:)
anyone know how to install the camber bolts?
they have a small tabbed washer but i have no recess for the tab to slot into to allow the washer to fit flush against the strut :S
Post Posted: Sat Apr 07, 2012 3:08 pm
The tab helps stop the camber bolt from moving.
It will fit, as the camber bolt shaft is offset
Users browsing this forum: No registered users and 101 guests
