It is currently Sun Nov 08, 2026 2:01 am
Vehicle: 2000 model Suzuki Jimny
Post Posted: Sun Apr 08, 2012 9:44 pm
Hi there,
Been thinking about doing a 2 inch lift for a little while now and just wondering what is needed. So far i have a bit of a list but if i need something or don't please feel free to adjust it. Most probably going to order from JimnyBits unless another brand is recommended.
- Jimny Bits 2 inch lift, ES3000 shocks
- Extended brake lines
- Adjustable Panhard arm set
- Panhard Relocation Bracket
That is all I can think of at the moment. Also, i would like to eventually run a bull bar and winch and was wondering if i would be able to do this with these products or if the front would sag.
Thanks,
Vehicle: 03 Jimny
Post Posted: Sun Apr 08, 2012 9:55 pm
My Jimny bits springs hold up with a bar and winch so shouldn't sag.
You won't need panhard relicating brackets either. Shouldn't need extended brake lines but if u have the money it would be good to invest in incase you go a bigger lift in the future.
Post Posted: Sun Apr 08, 2012 10:24 pm
Thanks for that. Just wondering, if it was to sag when a bull bar and winch are fitted would i be able to level it out by using spring spacers.
Thanks,
Post Posted: Sun Apr 08, 2012 10:38 pm
Yes you can
Post Posted: Mon Apr 09, 2012 3:22 am
Iv'e got the Jinmybits 2" lift on my jimny, and zooky08 is right you don't need longer brake line,and if your are buying the adjustable panhard rods you don't need the panhard relocation bracket.
Post Posted: Mon Apr 09, 2012 3:45 am
2 inch lift is all you will need, no panhards, no brake lines.
the front may sag, if you can get heavy duty springs for the front it could counteract the sag. spring spacers will level it out but then the flex will still be ghey as shit. and on full flex you may find it scrubbing on your bull bar.
if you get a winch and can afford it get the plasma rope instead of cable. much much lighter but just as strong.
have fun. great vehicle, will take you anywhere you need to go.
Post Posted: Mon Apr 09, 2012 9:02 am
Thanks for the help guys, It defiantly makes it easier to do stuff to the Jimny with a forum like this. And now i am able to order stuff from the UK and get the right stuff.
Thanks,
Vehicle: Sj70 tintop
Post Posted: Mon Apr 09, 2012 9:28 am
dm90 wrote:
2 inch lift is all you will need[b], no panhards, [/b]no brake lines.
the front may sag, if you can get heavy duty springs for the front it could counteract the sag.[b] spring spacers will level it out but then the flex will still be ghey as shit[/b]. and on full flex you may find it scrubbing on your bull bar.
but arent the adjustable panhards stronger??
can you tell me how the spring spacers effect travel? limit up travel??
and i think the rope is about 10%stronger than the wire rope, at least thats their advertising claim.
Sj70 tintop
Post Posted: Mon Apr 09, 2012 9:31 am
Fit the springs, wait 6 months for them to sag ( and they WILL) then fit some spacers to level it out again.
Post Posted: Mon Apr 09, 2012 9:33 am
Thanks, Do i need to order new bushes or anything or is this not required.
Post Posted: Mon Apr 09, 2012 9:37 am
If your bushes are worn or under sized, then replace them.
If it aint broke, don't fix it. ( Jimny dental floss Panhards being the exception to this rule :wink: )
Post Posted: Mon Apr 09, 2012 9:41 am
Thanks, i shall be placing an order soon.
Post Posted: Mon Apr 09, 2012 1:59 pm
wow. what a grilling :wink:
yes.
i stand corrected. (it made more sense in my head) :roll:
okay...... so the rope is stronger. the point was it's lighter and will therefore put less stress on the front springs.
Post Posted: Mon Apr 09, 2012 2:22 pm
^^ hahah nah just curious, wasnt meant to be a stabbing.
rope is a lot lighter wich will be a big point when choosing to throw it on the front of a zook.
can you shed any light on the coil spacers? i cant see how they would limit travel, but im happy to be told otherwise.
Sj70 tintop
Post Posted: Mon Apr 09, 2012 3:51 pm
i thought that if the springs were sagged to shit, lets say really bad to the point where the 'pitch'? of the spring is almost touching, so you add spacers to get the height back. but the spring is still shitty and still wont give much flexyness. not sure if there is any actual fact in that, just something i heard and sorta makes sense in my head. :roll: :roll: :lol: :lol:
maybe zukenutter can shed some light? he has used spacers before. any problems with limited flex/travel?
as for the panhards, i was saying you dont NEED them for a 50mm lift. but yes, they are stronger so if you want them and can afford them go right ahead.
also another quick tip, not sure on the jimny bits kit. but with the tough dog lift the drivers side spring, ie. the longer one, goes on the REAR right side.
Post Posted: Mon Apr 09, 2012 4:55 pm
LOL
I'll try and explain this in words as best I can.
Let's say a coil is 400mm long with the car's weight resting on it and that the car is sitting on flat ground.
If you install a 50mm spacer, the spring will still be 400mm but now the top of the coil is 50mm further away from the coil hat. The coil will still compress just as much as it could before but when the axle has travelled to the top of the coils compression it will be 50mm further away than it was without the spacer installed, giving an appearance of less up-travel.
The loss in overall travel will be, in effect, at the extension of the travel due to the shock EXTENDED LENGTH being unchanged. This is why I always say that the articulation is, to a large degree, controlled by shock length when extended and also compressed.
In a way the installation of spacers acts like bump stops limiting how close to the wheel arches the tyre can get.
A set of 50mm spacers and some well planned (by measurements) shocks would be a great way to cheaply lift a Jimny. 50mm wouldn't need any other mods, the axles would be slightly off centre but not enough to be noticeable.
I use the Outdoor Auto coil spacers and have a set of 50mm, 30mm and 15mm which I play around with a bit depending the coils I'm running.
His are designed specifically for a Jimny (not just a generic urethane ring like others I've seen) and are interchangeable front to rear.
Post Posted: Mon Apr 09, 2012 5:27 pm
what he said
:oops:
Post Posted: Mon Apr 09, 2012 6:58 pm
cool. that makes sense.
Sj70 tintop
Users browsing this forum: No registered users and 104 guests
