Joined: Tue Dec 13, 2011 12:20 am Posts: 166 Location: Perth
Vehicle: 1985 Sierra Hardtop
Posted: Wed Apr 11, 2012 8:35 pm
hello,
is there a trick to getting the front rotors off a Sierra?? i had a quick go at removing them but couldnt see how to get them off?? i didnt go too far with them though as i ran out of light. do i need to remove the locking hub parts or will the rotors slide off past it?
Posted: Wed Apr 11, 2012 8:44 pm
ah k i did see the bolt holes, i thought bolts were missing!! ha ha! i'm used to old cars like my Escorts that have a bolt or two to hold the drum on!! i will give that a go
If you are replacing the rotors the easiest way to remove them is to: Jack up front and place axle stands. Remove wheel. Remove caliper. Belt the rotor with a hammer until it falls off. Hit it anywhere except the wheel studs, hurting the rotor doesn't matter as it is going in the bin.
Users browsing this forum: No registered users and 107 guests
