It is currently Sun Nov 08, 2026 2:02 am
Post new topic Reply to topic  [ 30 posts ]
Vehicle: Suzuki sierra
Post Posted: Fri Apr 13, 2012 7:10 pm
I wanna get reduction gears for my sierra I still won't to keep my stock axle gearing.just won't to know what's the best ratio for me.i do a lot of 4wding and also use it as a daily car to get around in.
Post Posted: Fri Apr 13, 2012 7:17 pm
What size tyre do you plan to run, what gearbox do you have, what current diff gears do you have, what model of sierra is it and what motor are you running?
Post Posted: Fri Apr 13, 2012 7:20 pm
30 inch tyres 1.3l engine.standard gearbox it's a 1990.dont know what diff gears I'm running sorry
Post Posted: Fri Apr 13, 2012 9:23 pm
For 30 inch tyres i would say 4.9 or 5.14 at most and if you choose to go 31's the 5.14 will still do fine
Vehicle: 4wd
Post Posted: Fri Apr 13, 2012 9:24 pm
Tyre size?
Watch out or you'll get sued.
Post Posted: Fri Apr 13, 2012 9:25 pm
Look on the lowrangeoffroad website it says what ratio to use for what tyre size
I love lamp
Post Posted: Fri Apr 13, 2012 9:26 pm
For 30's i would say 4.9's or 5.14's
Post Posted: Fri Apr 13, 2012 9:45 pm
I fourby regularly and use my car daily
Vehicle: 1985 Holden Drover
Post Posted: Fri Apr 13, 2012 9:49 pm
Im leaning towards 4.9s just because of the amount of highway kms i do. Depends if your just doing suburbs and 4wding id go with the 5.14s imo?
1989 WT Sierra.
Post Posted: Fri Apr 13, 2012 9:56 pm
Do reduction gears give you more power
Post Posted: Fri Apr 13, 2012 10:00 pm
:roll: 2 thread in 2 different spots with the same posts :rambo:
Vehicle: 4wd
Post Posted: Fri Apr 13, 2012 10:03 pm
They do, but only about 12.975%. FUR would give you a slightly higher power increase, mix the two together and it could be lethal!
Post Posted: Fri Apr 13, 2012 10:19 pm
no they won't give you "more" power but will give you more gear reduction giving you back the "lost" power from larger tyres.
Vehicle: Ducati Monster
Post Posted: Fri Apr 13, 2012 10:23 pm
makes the power more "usable" by correcting the gearing that was changed by the size increase in the tyre
Post Posted: Fri Apr 13, 2012 10:24 pm
FUR plus dual discombobulators would be awesome!!! i put a NOS kit plus a supercharger on mine and it was fully sick bro!!
Post Posted: Fri Apr 13, 2012 10:28 pm
You're wrong Nintendo. My gears gave me 23hp.
Post Posted: Sat Apr 14, 2012 7:39 am
I daily drive on stock tyres with 6.5 gearing and a GTi motor which loves to rev even more than the stock 1.3L. After doing so I will always suggest more gearing is better, so if staying with 30's I would suggest the 5.14 transfer gears if not higher again, depending on the amount of highway km's you travel.
Post Posted: Sat Apr 14, 2012 9:54 am
Not wrong at all. You can't get more power than what you started with (ie, what an engine is capable of providing) by changing gearing of the vehicle. What you can do is regain what you have lost by messing with the original design by way of larger diameter wheels. By readjusting the gearing to suit the new treads, you shift the rev to road speed/rolling diameter ratio back to match the original design, or what suits your driving style/vehicle setup.
Otherwise it would be like saying... "I removed the back seats, the spare and half the guards and I got more power". Not possible. All you did was make the power you have be used more efficiently, or as mentiond just 'more usable'. Which is a good thing to do.
Post Posted: Sat Apr 14, 2012 9:56 am
What if i retro fitted one of those peter brock chips to the zook as well? Will i get more of an increase? :D
1989 WT Sierra.
Post Posted: Sat Apr 14, 2012 10:26 am
"I removed the back seats, the spare and half the guards and I got more power"..
:lol: I was joking.. what i said was exactly as retarded as that ^
Post Posted: Sat Apr 14, 2012 11:18 am
Ahh fair enough :)
Post Posted: Sun Apr 15, 2012 3:24 pm
I have the 5.14's on 30's in a stocko '90 WT, and the gearing is as per stock... still struggles to keep 5th gear on the hills, so i wouldn't reccoment 4.9's for highway work unless you live somewhere very flat
Post Posted: Sun Apr 15, 2012 3:51 pm
i run 5.14's and 31s on my sierra, but i've got a 1.6L EFI engine... IMO if you're keeping the 1.3 and going 31s you should get 6.5s - its only a few percent lower in high range but that few percent would be worth its weight in gold up a hill.
Post Posted: Sun Apr 15, 2012 4:14 pm
I have no issues with 5.14's and a 1.3 on 31's.
Post Posted: Sun Apr 15, 2012 4:40 pm
i cant see that the 2% diffrence of the high range is really relevent.... I think the choice of 5.14's or 6.5's should be made solely on your desired low range ratios.
Post Posted: Sun Apr 15, 2012 4:44 pm
x2. Some 3.9 diffs would even that out.
Post Posted: Sun Apr 15, 2012 6:05 pm
I honestly think the more gearing the better in high range for these little motors. Like I said, 6.5's and stock tyres and my zook is better to drive than ever on road, I wouldn't drive for hours at highway speeds though.
Post Posted: Sun Apr 15, 2012 6:46 pm
Yeah and there's the difference. I'm happy to sacrifice doing 110 on the freeway and just sit on 80-90. Others may not.
Post Posted: Sun Apr 15, 2012 8:36 pm
What is FUR
Post Posted: Sun Apr 15, 2012 8:46 pm
They're taking the piss because you posted the same question all over the place. Its an acronym for "Fronts in Rear" the opposite of what everyone does, which is "rears up front"
Lurk a bit more, do lots of reading and research, and post well-researched questions. It will avoid people making jokes at your expense.
Users browsing this forum: No registered users and 91 guests
