It is currently Wed Nov 04, 2026 12:09 pm
Vehicle: 03 Jimny
Post Posted: Sat Apr 14, 2012 10:50 am
need to top up my oils in my gearbox and transfer case in my jimny. transfercase will be easy as ill just fill it through the top of the gear stick hole, but im puzzled, how im going to fill the gearbox up with oil. i cant seem to find were the filling hole is on the box, and cant fill it from the top because jimny gearbox have linkages not a stick straight in the top. is it the bung thats on the side of the gearbox were the gear stick linkages enters into the gearbox?.
what is the easiest to fill the gearbox? a pump would be handy, but i only have a funnel and hose :x
cheers
Post Posted: Sat Apr 14, 2012 11:39 am
cheers
go buy something like this....
and the fill plug is on the drivers hand side of the box. (mine is a 01 non vvt m13)
so yes that is the plug
Edit: it should have a square in the plug where a 3/8 drive ratchet will fit. be careful not to round it
Vehicle: 07 vvt jimny
Post Posted: Sat Apr 14, 2012 6:12 pm
ohh the shame I rounded mine :( going to be a prick to get out
One tip!!
Dont do it when everything is hot i.e "gearbox and exhaust and shit" My plug was nice and soft since it was hot, and let me round/strip it out ha ha ha going to have fun with the chisel some day soon.
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Sun Apr 15, 2012 1:20 pm
3/8 drives can round the plug as it is a 10mm square adapter you need to fit tight
Post Posted: Sun Apr 15, 2012 4:03 pm
Just weld a M24 bolt to it :)
Also, your local bolt shop should have giant sump plugs. My Tcase takes a 27mm socket to undo :D
Vehicle: 03 Jimny
Post Posted: Sun Apr 15, 2012 6:59 pm
are you talking about the drain plug or the filler plug, because my gearbox hasnt got a square plug. its a hex head.
also that image doesnt work, so no sure what im buying :lol:
Post Posted: Mon Apr 16, 2012 7:57 am
I have been wondering the same thing. Also about the transfer case (no gear stick hole), as I've not tried yet.
Post Posted: Mon Apr 16, 2012 10:02 am
hmm pic worked the other day... fixed it now. it's just an oil lift pump...
cant believe you've never heard of one... should be able to get something similar at any auto parts shop.
both fill and drain holes in both the gearbox and transfer have the square 10 mm (haha can't believe I didn't know that) plugs
so you have hex ones... just fill the thing with oil.....
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Apr 16, 2012 11:16 am
I bought my 10mm square tool from ebay for about $10.
Turns out the other end has hex bits on it which actually annoying as I had already shelled out much more for the hex set I have for the same purpose on my old car.
Post Posted: Mon Apr 16, 2012 11:59 am
Like so. This will also work for 10mm square plugs...
viewtopic.php?f=5&t=10660
Post Posted: Mon Apr 16, 2012 5:02 pm
I rounded mine too :(
Took to it with a cold chisel and now it's really messed up :( :(
Tried to weld a bolt to it but my welding skills are a little lacking :( :( :(
I've been filling mine through my extended breather hose. No idea how much is in there :( :( :( :(
Vehicle: 03 Jimny
Post Posted: Mon Apr 16, 2012 9:28 pm
oh i heared of one for sure but all u did was post a picture, you didnt actually specify what i ment to buy and the picture wasnt work hence i had no clue what you trying to tell me what to buy. was going on a long trip just before i posted this thread so had no time to go buy anything
yea only plug that a square is my drain plug, filler plug is like 24mm or something
Post Posted: Mon Apr 16, 2012 11:37 pm
a picture tells 1000 words... if it works that is.
glad I could help :D
Post Posted: Tue Apr 16, 2013 12:02 pm
which location for plug and size of drive rachet do I need for a 2006 vvt jimny
ta for reading
Vehicle: Suzuki Jimny 2009
Post Posted: Tue Apr 16, 2013 8:09 pm
I have a 2009 VVT and the filler plug on the 5 speed manual box is on the passengers side almost directly above the cat convertor. It has a 10mm square plug and is really hard to get to. I got the dealer to replace my transmission oil and even they got heaps on the cat convertor.
Post Posted: Wed Apr 17, 2013 7:10 am
I bought this set after Atari shared the link - http://www.ebay.com.au/itm/130857371368?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1195wt_1413
I've always used a 3/8 drive ratchet but have rounded the gearbox plug twice by doing this. Buy the socket and save the pain. ;)
For those reading this who have a NON VVT Jimny I'm pretty sure the Non VVT gearbox has the filler plug on the other (driver) side.
Users browsing this forum: Google [Bot] and 65 guests
