It is currently Sat Nov 07, 2026 10:03 pm
Post Posted: Sat Apr 28, 2012 6:54 am
hey all i have a pipe bender on loan from a mate....im gunna make up a simple rear bar today....
BUT i like the look of these...
http://arb.com.au/products/arb-protecti ... s/4450010/
could you secure em to a sierra?
and how are they mounted? thanks
back in a built sierra!
Vehicle: 03 Jimny
Post Posted: Sat Apr 28, 2012 7:17 am
They look to be bolted through the sill
Same one here
http://www.google.com.au/search?tbm=isc ... ih=356#p=1
Post Posted: Sat Apr 28, 2012 7:26 am
Arb bar work is shit house
It's all weak and bends first time u use it
U want at least 3 legs back to the chassis
-I seen them bolted to the body mounts and a u clamp in the middle
-3 pipes welded to fish plates then welded to chassis( did this to my coily wouldn't do it again)
-3 bits of c Chanel with 4 nuts welded on the back then welded to chassis
Legs have a plate welded on end that bolts to the c chanel( did this on a patrol worked really good
Make sure u use a strong enough pipe or it will just bend
I had 25 nb on my coily and it bent
Post Posted: Sat Apr 28, 2012 7:32 am
i got 32mm pipe here....i think its about 2 or 3mm think....is that ok?
i bent the arb bar on my patrol easy as!
i just like the look of these sliders....
my sills are al ready pretty hammered! would only be for looks....
ya reckon if i got some sheet steel bent like an L with the bottom bein smaller to go just under the sill....then i weld my pipe work to that...then have some some steel on the other side to sill to sorta sandwitch it together it would be strong enough to stand on? to use as like a side step?
Post Posted: Sat Apr 28, 2012 7:53 am
That's how mine are made
Sorry don't have Any good close up pics
They are 75x50x 5 angle
A bit heavy but haven't bent and cop a absolute flogging
My mount aren't that strong but they have held up fine
Post Posted: Sat Apr 28, 2012 7:56 am
Lucky on the vit a the rear two mounts go in to the existing cross members Image
Post Posted: Sat Apr 28, 2012 8:38 am
ah yep gotcha!
cheers bud! was hopin to not have any thing hangin down to hung up on....my sills are fair beatin up!haha
see what i can work out!
cheers for ya help!
Post Posted: Sat Apr 28, 2012 10:30 am
like this?
Post Posted: Sat Apr 28, 2012 10:37 am
They look so good
How do they go only being bolted to the body
Have they taken any big landings on a rock
Are they strong enough to hold the entire weight of the car on
I'm surprised how strong mine are with only the 8pm flat bar joining the legs to the angle
Post Posted: Sat Apr 28, 2012 11:01 am
got_bar_work wrote:
They look so good
Mate these are serious kit not just for looks, heaps of design work in these to make them strong you will not get better, if I had a Sierra they would be on it, I reckon they are as good as you will get as far as being totally functional and yet looking awesome.
Post Posted: Sat Apr 28, 2012 11:18 am
2stroker wrote:
got_bar_work wrote:
They look so good
Mate these are serious kit not just for looks, heaps of design work in these to make them srong you will not get better, if I had a Sierra they would be on it, I reckon then are as good as you will get as far as being totaly functional and yet looking awesome.
Cheers 2stroker.
got_bar_work: Chassis mounted sliders are only as strong as the cross sectional area of chassis they are held captive by. And sierras don't have the biggest/ strongest chassis around either. Given the distance that the point of impact usually is from the chassis, the 'outrigger' style mounts that are necessary on chassis mounted slider create a rather large lever.
Body mounted sliders ( not mounted correctly) can create as much damage as the rock you are trying to protect the sills from. They key is to look at how the force will be distributed in a heavy upward impact.
Also, I'm not a fan of mounting to the chassis AND the body, like some people do. Its poor practice, and doesn't allow for body/ chassis deflection, and could lead to premature cracking of the body/ chassis.
Post Posted: Sat Apr 28, 2012 11:43 am
Got any more pics of your sliders Fatzook?
Can't figure out their strength from that pic..
Post Posted: Sat Apr 28, 2012 12:14 pm
I have no problem with the sliders they look great it was more the strength of the Sierra body I was worried about
Ive read alot of things a out sierra cracking body mounts
So I was wandering if u took a big drop onto the slider would the weight of the chassis that Is hanging off the body studs cause them to tear out
Post Posted: Sat Apr 28, 2012 1:31 pm
Yeah - Fatzook's sliders are the best I've ever seen. It's just a pity the Jimny ones weren't ready when I decided to buy mine.
Better than stock...but not by much.
 Profile YIM
Post Posted: Sat Apr 28, 2012 10:48 pm
Your sills are fucked, so its irrelevant :thefinger:
Post Posted: Sat Apr 28, 2012 11:43 pm
Haha, im just curious where they mount, cos chassis mount sliders are gay.
Post Posted: Sun Apr 29, 2012 12:06 am
They bolt through the sill from outside to inside, and up through the floor.
Post Posted: Sun Apr 29, 2012 12:12 am
Ahh! Makes more sense. Very nice!
Post Posted: Sun Apr 29, 2012 10:17 am
You should boatside yours. Or weld in RHS. :wink:
Post Posted: Sun Apr 29, 2012 1:09 pm
Yeah, looking at a mates truggy he has boatsided sills with a slider outside it. Looks like an idea.
Post Posted: Sun Apr 29, 2012 1:20 pm
IMO there is no piont boatsiding if you are going to run a slider aswell.
just boatside with 5mm plate, gussets behind it, and enjoy the extra clearance :wink:
Post Posted: Sun Apr 29, 2012 1:27 pm
You reckon that will hold up to the full weight of the car landing on a single point?
Also, the exo was going to bolt to the sliders.
Post Posted: Sun Apr 29, 2012 8:28 pm
Has anyone done this to a jimny?
Post Posted: Sun Apr 29, 2012 8:57 pm
The shape of a jimny sill is infinately more complicated. Not saying it couldn't be done, but it would be a MASSIVE undertaking!
Post Posted: Sun Apr 29, 2012 9:24 pm
...... well something to think about. I like the idea of making the sills them selves the sliders rather than attaching something to the chassis.
Users browsing this forum: Google [Bot] and 84 guests
