It is currently Sun Nov 08, 2026 5:38 pm
Post Posted: Sat May 12, 2012 9:27 am
Hi guys,
This is driving me nuts! I've got a '91 SWB Vitara. When the car starts in the mornings it runs rough. When she's warm (after about 5-10 minutes of driving) it goes fine. I had the local mechanic replace the carbie, but it made no difference. Now that I followed it up further, it seems like it's the front cylinder that is missing. I swapped plugs around, but it's still the same.
Would it be the distributor? I sprayed WD40 in it, but no difference. Maybe the HT leads? A dodgy earth somewhere? I'm stumped.
I've looked over the net and haven't found anything yet. Any ideas?
Cheers, Tim.
Post Posted: Sat May 12, 2012 5:45 pm
Have you checked that the auto choke is working?
Have you tried swapping leads around to eliminate them as a cause?
Post Posted: Sat May 12, 2012 5:54 pm
Cold big boy......
Are you using coolant???
Post Posted: Mon May 14, 2012 2:29 pm
Aha! (Not the 80's band.) I got new plugs and leads and the problem is now fixed. Initially I just swapped the plug and lead on the front cylinder and the problem went away, but I figured I may as well swap them all.
I even went as far as draining and ditching all the fuel before to see if that was the problem. It wasn't ;-)
Thanks for your help.
Vehicle: 96 vit hardtop
Post Posted: Sun Jun 24, 2012 7:39 am
I'm having the same issues, but I got an EFI version....I'll give the plugs and leads a go. Yet to do a full proper service on the thing..
Post Posted: Sun Jun 24, 2012 10:58 pm
Hey mate,
$6.50 per HT lead from the local servo. Which, added up, is still half the price of a set from any of the auto shops. Go figure...
Mine runs fine now. Never done a proper service either.
Users browsing this forum: No registered users and 80 guests
