[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Tizza
Joined: Wed Jan 27, 2010 10:30 pm Posts: 21 Location: Gold Coast
 Posted: Sat May 12, 2012 9:27 am |
Hi guys,
This is driving me nuts! I've got a '91 SWB Vitara. When the car starts in the mornings it runs rough. When she's warm (after about 5-10 minutes of driving) it goes fine. I had the local mechanic replace the carbie, but it made no difference. Now that I followed it up further, it seems like it's the front cylinder that is missing. I swapped plugs around, but it's still the same. Would it be the distributor? I sprayed WD40 in it, but no difference. Maybe the HT leads? A dodgy earth somewhere? I'm stumped. I've looked over the net and haven't found anything yet. Any ideas?
Cheers, Tim.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sat May 12, 2012 5:45 pm |
Have you checked that the auto choke is working?
Have you tried swapping leads around to eliminate them as a cause?
steak_knife
 Posted: Sat May 12, 2012 5:54 pm |
want33s wrote: Have you checked that the auto choke is working?
Have you tried swapping leads around to eliminate them as a cause? Cold big boy...... Are you using coolant???
Tizza
 Posted: Mon May 14, 2012 2:29 pm |
Aha! (Not the 80's band.) I got new plugs and leads and the problem is now fixed. Initially I just swapped the plug and lead on the front cylinder and the problem went away, but I figured I may as well swap them all. I even went as far as draining and ditching all the fuel before to see if that was the problem. It wasn't  Thanks for your help.
oohsam
Joined: Mon Apr 30, 2012 7:12 pm Posts: 489 Location: south east melbourne
Vehicle: 96 vit hardtop
 Posted: Sun Jun 24, 2012 7:39 am |
I'm having the same issues, but I got an EFI version....I'll give the plugs and leads a go. Yet to do a full proper service on the thing..
Tizza
 Posted: Sun Jun 24, 2012 10:58 pm |
Hey mate,
$6.50 per HT lead from the local servo. Which, added up, is still half the price of a set from any of the auto shops. Go figure...
Mine runs fine now. Never done a proper service either.
[ 6 posts ] |
Users browsing this forum: Google [Bot], phlix and 51 guests
