It is currently Fri Oct 02, 2026 10:12 pm
Vehicle: Suzuki Grand Vitara
Post Posted: Sat May 19, 2012 11:47 am
Ok I would like to upgrade the Suspension on my Sierra.
Have looked into different brands. (Internet based)
The Calmini 3" or 3.5" looks like a good option.
There are heaps on eBay would know a good setup from a bad on there.
Could I get opinions from everyone on here, will look into any setup even mix and match brands.
Will be buying another set of 30" mud tyres, maybe 31" if they don't scrub.
Tyres and wheels will be used on both my Vitara and Sierra.
Cheers,
Dave
Post Posted: Sat May 19, 2012 12:54 pm
What suspension do you have atm?
Post Posted: Sat May 19, 2012 12:58 pm
Original 1995 Suzuki Suspension.
Post Posted: Sat May 19, 2012 1:41 pm
What are you after?
More flex? Better ride? More clearance? Some more height to clear some tyres? Poser looks?
Post Posted: Sat May 19, 2012 3:34 pm
Used OME springs and U bolts, nuts, washers etc….
Gabriel Front Hiace shocks and rear VS/VR wagon shocks…
And poly bushes from online auto parts
I use this setup...works well...Need extended bumpstops for the front tho... :wink:
Vehicle: chick magnet coily
Post Posted: Sat May 19, 2012 4:26 pm
SPOA = 8)
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Sat May 19, 2012 4:42 pm
fully sick coily wrote:
SPOA = 8)
:roll:
Post Posted: Sat May 19, 2012 4:57 pm
sideways wrote:
What are you after?
Yes to all three.
Increasded Clearance.
More Flex.
Too fit larger tyres.
Ride, don't care much...... it's a Suzuki.
Post Posted: Sat May 19, 2012 5:00 pm
SPOA = 8)
NO! will not be a SPOA.
Post Posted: Sat May 19, 2012 5:04 pm
You dont need 3.5 inch lift for31's. Matter of fact you dont need any lift.
But if you want some chassis clearance i would go
2inch spring
Ruf
Virtual lift/ guard chop
Look for a well known 2inch spring on the market.
Ome and efs springs are pretty good.
Post Posted: Sat May 19, 2012 7:10 pm
SPOA = 8)
oohhh :oops:
Post Posted: Sat May 19, 2012 7:16 pm
i run 2 inch efs leafs with 31 inch tire's and efs shocks but there the same length as the commodore, hiace shocks that people run but overall i am pleased with it
Vehicle: 85.Ruf. rear air locker
Post Posted: Sun May 20, 2012 8:27 am
Running ome with ruf with commo shocks up front
Just need longer shocks for the rear
But its a nice ride of road :)
Vehicle: Sj413k,35" silverstones
Post Posted: Sun May 20, 2012 1:47 pm
I used to run 32s with only extended shackles an extended front bump stops.. And it only thing it rubbed on was the leaf springs at full lock.
Post Posted: Sun May 20, 2012 10:30 pm
Ruf -1 leaf Spoa OMEs and most importantly a PANHARD rod. So good.
So so good.
Not like a Sierra at all.
Actually good.
Post Posted: Mon May 21, 2012 8:13 am
Panhard? Do you mean track bar?
Spoa sucks balls JMO.
its a yank think to get a zook and spoa it but its just not parctical.
There is no reason for it unless u like to change everything for very little gain.
If you were gunna go to the trouble of spoa you may as well just coil it.
If you ruf it and also move the hangers on you rear aswell to get good shackle angles at both ends you will get much better perfomance for relatively little work.
I love lamp
Users browsing this forum: No registered users and 163 guests
