It is currently Sat Nov 07, 2026 7:29 pm
Vehicle: 96 Sierra Tintop swb nt coily
Post Posted: Thu May 31, 2012 9:01 pm
i acquired some 60mm solid aluminium bar and made some blocka up but i only made 8 as this is all i can see but when i look at kits for sale online they have 10 blocks. is this corrrect or will 8 be ok?
Post Posted: Thu May 31, 2012 9:03 pm
For a SWB sierra? 10 blocks. And the 60mm diameter blocks won't fit at the back.
And what have you done about the captive studs in the floor? The bolts aren't removable.
Post Posted: Fri Jun 01, 2012 8:16 am
i pulled the blocks down to 52mm. was un aware of the captive studs thanks for the heads up what would you recommend?
Post Posted: Fri Jun 01, 2012 8:21 am
I would recommend selling your blocks to someone with a Hilux and buying a kit off here.
The studs are a pain unless you have female bolts, Which have to be high tensile if you want anything to be legit.
Alot of work to cut out the studs and replace with bolts for a simple bodylift.
Vehicle: Coily sierra..30" muds
Post Posted: Sat Jun 02, 2012 5:48 pm
Wheres a good place to purchase a body lift?
Post Posted: Sat Jun 02, 2012 5:54 pm
viewtopic.php?f=15&t=15518
Vehicle: 1985 Holden Drover
Post Posted: Sat Jun 02, 2012 5:58 pm
http://www.auszookers.com/forum/viewtopic.php?f=15&t=15518
x2.
Worth the money for sure! Its a great kit and comes with really good instructions.
1989 WT Sierra.
Post Posted: Sat Jun 02, 2012 6:21 pm
x2.
x3
Post Posted: Sat Jun 02, 2012 6:42 pm
Or here if you prefer ally blocks :peaceout:
viewtopic.php?f=15&t=13126
Scroll down the bottom of the page
