It is currently Sat Nov 07, 2026 5:35 pm
Vehicle: 08 jimny all stock atm
Post Posted: Sun Jun 03, 2012 4:10 pm
hey guys was at the power lines having some fun after all the rain
driving through some water it got deep fast and the air box filled with water ......motor turned its self off
i opened the air box to find it full of water :( .... i got all the water out to find a small drain hole that couldnt deal with the dirty mud water
fired it up no worries just some steam out the exhaust drove home no worries , but theres an engine light on ? can anyone give me some details on this ?
ps ill be buying a snorkel now lol
Post Posted: Sun Jun 03, 2012 4:26 pm
might be buying a new motor before the snorkel.... 8O
should have check for water in the cylinders by removing the spark plugs before starting, does it still run smooth?
disconnecting the battery for a couple of minutes should clear the error code but really you want to get the codes out of the ECU first.
Post Posted: Sun Jun 03, 2012 4:37 pm
didnt have any tools with me :?
motor seems fine its running perfect , done about 100kays since the water
Post Posted: Sun Jun 03, 2012 4:43 pm
not sure about the different series of jimny's but is this any help?
viewtopic.php?f=5&t=24815&p=442843&hilit=jimny+code#p442843
Moag wrote:
This is as far as I've got with understanding my little bus!! :blink:
Moag's pictures were awes.... where are you Mr Moag?
Post Posted: Sun Jun 03, 2012 6:16 pm
pull your dipstick and take off the oil filler cap and see if its gone milky... you might be lucky and get away with changing the oil and thats all.
next time check the depth of each puddle before you drive it =)
Post Posted: Sun Jun 03, 2012 7:45 pm
Could be a simple as leaving the air sensor off the airbox lid will bring up a engine light:)
dodgy brothers mechanical
Post Posted: Mon Jun 04, 2012 6:21 am
could have also bent a conrod by trying to compress water. dunno how that would bring up a error code tho. and it would probably seize the engine. but trying to compress water in a engine usually causes problems cause you cant compress water.
Vehicle: 06 Jimny VVT
Post Posted: Mon Jun 04, 2012 7:15 am
When I did the same in my 06 VVT, i was not as lucky as you and ended up with a massive knock in the bottom end. I put another motor in as I could not be stuffed mucking around with the engine, but once we got it started once we got all the water out of it, the engine light was on. Now I dont know if it has something to do with the internals that where stuffed or water had come in contact with the air flow sensor. Once I fitted the new motor the light has not come on. It maybe because the sensor dried out. I did not change the sensor. Cant be certain.
Post Posted: Mon Jun 04, 2012 5:12 pm
I'd change the oil
Post Posted: Tue Jun 05, 2012 5:22 pm
i dont think theres any damage to my engine internals (oil is gold ) no knocks and makes normal power
got around to changing the air cleaner today with a brand new one has soon has i started it up the light went out so problem over :D
cheers for ya help
Users browsing this forum: No registered users and 69 guests
