It is currently Wed Nov 11, 2026 9:13 pm
Vehicle: Sierra Shooting Buggy
Post Posted: Fri May 25, 2012 10:44 am
I have an older leaf spring Sierra that we use as a shooting buggy, it travels on a trailer and will never be registered. My plan is to convert it to a Vitara auto gearbox (to free up my gear change hand). I plan to use a modified and complete Vitara rear axle (5.12 ratio). I am after info on what is required to alter the front diff to a 5.12 ratio, I have an old Vitara front diff centre, I understand I use the crown and pinion gears but what other tricks are required? I am sure this would have been covered in detail previously so if you could point me in the right direction it would be much appreciated. Cheers.
Post Posted: Fri May 25, 2012 12:10 pm
the R&P from a 5.12 Vitara front will fit a sierra 1.3 diff
Post Posted: Fri May 25, 2012 5:30 pm
Because ring gear is slimmer,
may need something to stop cross pins falling out.
Many solutions to that.
Post Posted: Fri May 25, 2012 9:15 pm
Gyro_bob wrote:
I am after info on what is required to alter the front diff to a 5.12 ratio, I understand I use the crown and pinion gears.
That's the way it's done.
Your older front front Sierra carrier will have the stronger 4 spider gears, but as Christover said, the OD of the case will be smaller than the ID of the ring gear and you need SOMETHING LIKE THIS to retain the pins. Alternatively, you could fit the marginally weaker 2 spider centre from the Vitara and not need the retainer sleeve. You need to have a good understanding of diffs to correctly set up the Pinion depth and R+P backlash, or get a Diff workshop to do it for you. Have a read of the Differential section of the WORKSHOP MANUAL.
Post Posted: Sat May 26, 2012 10:16 pm
Can front and rear 4.8 gv r&ps be used in the seirra diff?
Post Posted: Sat May 26, 2012 10:24 pm
Vitara rear diffs use a larger ring n pinion,
so rears can't be used in Sierras.
Only the fronts.
I assume GV is the same.
Post Posted: Tue Jun 19, 2012 7:22 pm
Just found this thought it might come in handy for others concidering this swap also good for 4:6's (Good write up!)
http://www.zukikrawlers.com/showthread.php?t=4215
Cheers Robb.
Bitumen...Another waste of public funds!
Users browsing this forum: Google [Bot] and 92 guests
