It is currently Wed Nov 11, 2026 1:07 pm
Vehicle: 96 LWB Vit, 2.5L powerhouse
Post Posted: Sat Jun 16, 2012 12:13 pm
Hey guys, i have a v6 vit and i noticed a small pool of coolant under it this morning. I assume the water pump has gone. The best i can see is the coolant is dripping out of an unplugged hole behind the main crank pulley. I think. Does this sound normal? Also it looks like its going to be fun to replace, i have a leaking rear main im fairly sure as well.
Options :1 Pull engine out and put a 2.5 :)
2 Replace water pump
3 Pull engine out and replace water pump and clutch and rear main.
4 Burn it.
1997 Sierra, daily driver, 60mm coils, 2 inch body
Post Posted: Sat Jun 16, 2012 12:16 pm
Sounds like the water pump to me.
How you repair it is up to you.
Post Posted: Sat Jun 16, 2012 12:23 pm
Cheers want 33's. Have u replaced one before? To be honest i cant even see where it is?
Wow these engines come out and pull apart quick..... IS that it?
Post Posted: Sat Jun 16, 2012 12:47 pm
Well i think i have made up my mind. The engines coming out and a 2.5 is going in. Have to start it eventually so why not now. (also a sneaky way to not let the missus no im upgrading the motor).
Anyone know of a low km 2.5 v6 for sale?
Post Posted: Sat Jun 16, 2012 2:07 pm
Yep that is the pump.
Post Posted: Sun Jun 17, 2012 7:59 am
Is it possible for me to pull the motor and gearbox from a 2.0l v6 vit in one go. If i remove the radiator to give me some more clearence then maybe??
Post Posted: Sun Jun 17, 2012 8:07 am
I haven't tried it but I'd say it wouldn't be easy as the gearbox/transfer is quite long.
I'd undo the bellhousing bolts and remove them seperately.
Post Posted: Sun Jun 17, 2012 9:26 am
Yeh cheers mate sounds good. there is 4 bellhousing bolts and then 2 studs with nuts on them. Does the starter motor have to come out first or is it attached to the bell housing.
Post Posted: Sun Jun 17, 2012 11:16 am
take the starter out. will give you a bit more room to play with. form memory i think there are two studs attached to the bell housing
Post Posted: Sun Jun 17, 2012 11:24 am
:peaceout: Ok cheers mate. I should only have the starter and i have to cut the two bolts where the exhaust meets up they are as rusty as a nuns.......
And then she is ready to pull. Might have jumped the gun a bit though as i dont have a replacement. hahah. Does anyone know any go fast things apart from forced induction u can do to salvage some more power out of these?
Post Posted: Sun Jun 17, 2012 11:26 am
speak to dezook, he's just boosted a H25a in a SV620
Users browsing this forum: No registered users and 50 guests
