It is currently Sat Nov 07, 2026 1:01 am
Post new topic Reply to topic  [ 30 posts ]
Vehicle: LJ80
Post Posted: Wed Jun 20, 2012 10:08 am
i have a 99 GV with the steel front diff
the front diff does not engage but the air pump works fine
any idea's ?
can i strip the diff and lock it (not diff lock )
then use vit hubs to engage /disengage 4wd ?
or what other options are open for me ?
Post Posted: Wed Jun 20, 2012 10:22 am
Define "works fine" - how did you test it?
Just so you understand where I'm coming from, if you're hearing the pump running it doesn't mean it works fine, you can still have a defective pump even though it pumps air.
If the freewheel clutch actuator has in fact failed, your options are to fit a diff center from an earlier Vitara (just don't ask me which one), manually engage the clutch and then either weld it engaged or lock it in position with nylon cable ties.
Post Posted: Wed Jun 20, 2012 11:01 am
here is a good link on the GV pump viewtopic.php?f=17&t=19613&hilit=GV+pump but the pics seem broken. :?
Vehicle: LJ80
Post Posted: Wed Jun 20, 2012 11:40 am
i have no nor have i ever had a 4wd light on the dash (but i did buy second hand )
pump operates for aprox 3 seconds connected and about 10 with the line disconnected i can feel air coming out of the line
so i assume the pump is operating
thanks for the link Atari
i have a link to a pommy site that has the cable tie fix
Vehicle: Sold zuk got a Bt50
Post Posted: Wed Jun 20, 2012 4:08 pm
I would replace the whole center with a vit one, manual hubs and put a new bush and seals in there to stop the CV popping out. becomes all manual then and fool proof
this is the seal im talking about
viewtopic.php?f=17&t=6953
Post Posted: Thu Jun 21, 2012 2:56 am
Must've gotten lost during the server migration - I'll see what I can do to repost them this evening.
Post Posted: Thu Jun 21, 2012 3:02 am
That does sound like the pump is fine, but, it would be extremely rare for the pump to cut off after 3 seconds without engaging the freewheel clutch - unless there was a blockage in the line between the two.
Can you get hold of a hand pump?
This is what I use - connect it to the diff and with no more than 10 psi, you should hear the actuator transfer and if you rotate the front drive shaft, you should feel it click in.
Post Posted: Thu Jun 21, 2012 11:49 am
You say the 4wd light on the dash doesnt work? is it the globe or a fault in the air operation?
Post Posted: Thu Jun 21, 2012 12:24 pm
i replace the center of my GV for a vitara one so no more air bag, still kept the compressor just plugged the outlet and i still had the light in mine.
Vehicle: LJ80
Post Posted: Thu Jun 21, 2012 1:16 pm
light what light ?
until Coffin bay i thought only sierra's had such a high level of technical wizardry
i will rip out the dash and have a look at the bulb
Vehicle: LJ80
oops double post
Vehicle: LJ80
as above :roll:
Vehicle: LJ80
Post Posted: Thu Jun 21, 2012 2:16 pm
well i do have a light. and the bulb is good. but it does not light up when the transfer lever is put in 4wd :(
Post Posted: Thu Jun 21, 2012 3:38 pm
Hmm, wonder if the transfer is working?
Vehicle: LJ80
Post Posted: Thu Jun 21, 2012 5:49 pm
i will put it on stands in the morning and find out
Post Posted: Fri Jun 22, 2012 2:44 am
Some GVs have a separate 4WD controller, some have this function built into the ECU/PCU (power train controller - handles buth engine & transmission) - the controller turns the light on & off based on electrical feed back from the pump module - a defective pump module OR a problem internal to the diff can cause the light not to turn on - in fact, typically anything preventing 4WD from being engaged will result in the light not coming on.
It's possible to reach the front drive shaft without jacking the vehicle up (at least I can), just set the hand brake, select 4HI, engine off, slide under, grab the drive shaft & twist it - it should not turn.
Vehicle: LJ80
Post Posted: Fri Jun 22, 2012 7:41 am
the front drive shaft does not turn in 2wd or 4wd with handbrake on and gearbox in neutral
nor does it turn in 4wd when front wheels are jacked up and spun by hand
Vehicle: LJ80
Post Posted: Sun Jul 01, 2012 5:30 pm
i put my rear axle on stands today and idled in first gear.
then i changed from 2wd to 4wd without using the clutch.
after about twenty changes there was a loud bang from
under the car and it tried to pull off the stands.
so i think i have 4wd back but now the ABS light
is lit at all times. any ideas on this ?
i have read that if you do not use the 4wd system it becomes hard to select
and i was told when i bought it that this car had never been off road
so 12 years no use..............................
Post Posted: Sun Jul 01, 2012 5:56 pm
8O safe
before disconnecting the battery pull error codes to see if there are any & then disconnect it for a few minutes to clear the ecu & see if any come back.
there is an attachment nearly at the bottom of this page on how to pull the codes
viewtopic.php?f=5&t=6451&hilit=j20a+error+codes
SQ625 codes are in here
viewtopic.php?f=5&t=31555&hilit=j20a+error+codes
Vehicle: LJ80
Post Posted: Sun Jul 01, 2012 6:06 pm
8O safe
http://www.auszookers.com/forum/viewtop ... rror+codes
i should have mentioned that i have disconnected the battery for 15 min before i posted
Vehicle: LJ80
Post Posted: Tue Jul 03, 2012 12:28 pm
o/k
i pulled the codes this morning
only one code 12
anyone know what that is ?
i can not find any info on it ..... yet
Post Posted: Tue Jul 03, 2012 12:42 pm
auto or manual?
Vehicle: LJ80
Post Posted: Tue Jul 03, 2012 1:10 pm
manual
Post Posted: Tue Jul 03, 2012 10:14 pm
A code 12 indicates the ECU is not detecting any errors - and on a manual transmission vehicle, you're unlikely to see any codes that relate to the transmission or transfer case (or 4WD control system), they're not controlled by the ECU.
Post Posted: Wed Jul 04, 2012 6:44 am
Awsome. An error code to tell you there are no errors detected. WTF.
Vehicle: LJ80
Post Posted: Wed Jul 04, 2012 8:01 am
so my engine is good
my 4wd works
my 4wd light does not
and my abs light is on
no broken wires or dud connections that i can find
time to grab the multimeter and rip the wheels off
abs light is off Armsup
step two started with " take it for a road test"
the light cleared before i got out of the driveway :oops:
thanks for all your help
Post Posted: Wed Jul 04, 2012 1:39 pm
Sorry to hijack
Stupid idea
Could u put a gv diff in the sierra rear
Then u could disconnect it and do front digs
Post Posted: Wed Jul 04, 2012 3:35 pm
got_bar_work wrote:
Sorry to hijack
Stupid idea
No you cannot. GV diff center is bigger than sierra
Post Posted: Wed Jul 04, 2012 6:19 pm
I thought the fronts were the same as rears
Gears fit and im running a sierra hemisphere in my gv carrier
Vehicle: 2002 GV V6 and self shifter
Post Posted: Thu Jul 05, 2012 11:36 am
laurie wrote:
but now the ABS light is lit at all times. any ideas on this ?
This ^^^^^^ is due to doing this vvvvvvvv
The ABS system registers the rear wheels moving but the front wheels not and after a set nubmer of rotations or distance or time considers the front sensors (at the wheel) to be faulty due to no signal and goes "Hey dude, look at this pretty light on the dash that tells you something is wrong"
As soon as you drive and all wheels are moving and all sensors are registering that they are moving the ABS will think all is well and turn of the light
Users browsing this forum: Google [Bot] and 93 guests
