It is currently Sat Nov 07, 2026 12:17 pm
Post Posted: Wed Jun 20, 2012 9:52 pm
hey guys well i got my NT Suzuki abit wet long story short after spraying some wd40 i had the car running but then it stalled seems im getting no spark from the ignition Coil
now i had a look and its quite different to a WT coil dont know if its just this car or its all NTs but it seems to have a Resistor that was smoking
basically what i need is photos of a NT ignition coil and or better yet wiring diagram
Because i cant remember what goes where :oops: any help would be great thanks
Vehicle: SJ51T
Post Posted: Wed Jun 20, 2012 10:13 pm
You'll find a drover wiring diagram here
http://www.suzukiinfo.com/
Post Posted: Wed Jun 20, 2012 10:14 pm
thanks il take a look should help a bit
Post Posted: Wed Jun 20, 2012 10:23 pm
Resistor smoking?
Sounds like 1.0 electrics not 1.3
Post Posted: Wed Jun 20, 2012 10:30 pm
it is a 1.0 lol NT LWB
Post Posted: Wed Jun 20, 2012 10:41 pm
Wants 33s i saw u saying something about a
Ballast Resistor i think thats what was smoking it was mounted on the coil braket with a few leads going to it ..
Post Posted: Wed Jun 20, 2012 11:11 pm
You should be able to buy a new ballast at any decent autoparts shop.
Lots of older cars have them especially jap stuff so if there are old hiluxes/datsuns etc around your area check them out.
Alternatively:
Throw away the ballast and fit a 1.3 electronic dissy and coil.
Post Posted: Wed Jun 20, 2012 11:51 pm
i have a 1.3 electronic dissy does it bolt right up ?
i have a 1.3 electronic dissy does it bolt right up ? and does the ballast need to be a specific size ?
Post Posted: Thu Jun 21, 2012 7:32 am
1.3 dissy bolts straight into a 1.0 or 1.3 engine.
1.3 dissy needs full 12V so remove the ballast as it reduces power to points down to about 7.5V.
Post Posted: Thu Jun 21, 2012 11:20 pm
ok well still scratching my head over this one ... this is what iv got to
Black and white stripe goes to ballast then to + on coil
blue wire from back of dizzy goes to - on coil has some sort of reg on it ;S
yellow and white stripe i think goes to positive on coil .. seems to be ignition ...
then i have red with white stripe ?
and someone also had another earth going out of back of dizzy to fire wall
Help please haha photos of NT coil with wires could help me alot please
Vehicle: LJ50V, SJ70
Post Posted: Fri Jun 22, 2012 11:19 am
It's not NT you want, it's 1.0lt.
1.3lt NT will be different to what you have.
Users browsing this forum: No registered users and 78 guests
