| Author |
Message |
ROAR99
Joined: Sat Jul 16, 2011 8:31 am Posts: 190 Location: brisbane
 Posted: Sat Jun 23, 2012 1:37 pm |
looking for a tyre to put on the factory spare rim (w/t sierra) runin 31/10.5/15 on the car but wanted a skinny 15" same hight as the 31,s amy suggestions?
Matthew
Joined: Mon Jun 15, 2009 11:30 pm Posts: 472 Location: S.E. Melbourne
Vehicle: SWB Sierra
 Posted: Sat Jun 23, 2012 1:52 pm |
Not a 15, but 215/85r16 is nice and skinny and not much smaller than a 31.
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Sat Jun 23, 2012 1:54 pm |
ROAR99 wrote: looking for a tyre to put on the factory spare rim (w/t sierra) runin 31/10.5/15 on the car but wanted a skinny 15" same hight as the 31,s amy suggestions? Basically, no. Not unless you consider 9.5" skinny. You'd be better off sourcing a 16" rim and wacking a 7.50x16 on it. 7.50x16s almost always measure 31" and are very cheap and easy to get.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sat Jun 23, 2012 2:01 pm |
Just stick a 31 on the standard rim, it'll be alright for a spare
3cyl
Joined: Tue Jan 29, 2008 10:30 pm Posts: 2054 Location: Ipswich
 Posted: Sat Jun 23, 2012 4:45 pm |
sideways wrote: ROAR99 wrote: looking for a tyre to put on the factory spare rim (w/t sierra) runin 31/10.5/15 on the car but wanted a skinny 15" same hight as the 31,s amy suggestions? Basically, no. Not unless you consider 9.5" skinny. You'd be better off sourcing a 16" rim and wacking a 7.50x16 on it. 7.50x16s almost always measure 31" and are very cheap and easy to get. Most 7.50/16s are between 808 and 812 mm, closer to 32". only option on a 15 might be a 700/15 which would be a gay, uber heavy truck tyre.
_________________ awesome only comes in 2 colours, camo & bare metal
sideways
 Posted: Sat Jun 23, 2012 5:04 pm |
3cyl wrote: sideways wrote: ROAR99 wrote: looking for a tyre to put on the factory spare rim (w/t sierra) runin 31/10.5/15 on the car but wanted a skinny 15" same hight as the 31,s amy suggestions? Basically, no. Not unless you consider 9.5" skinny. You'd be better off sourcing a 16" rim and wacking a 7.50x16 on it. 7.50x16s almost always measure 31" and are very cheap and easy to get. Most 7.50/16s are between 808 and 812 mm, closer to 32". only option on a 15 might be a 700/15 which would be a gay, uber heavy truck tyre. Most of the ones I've measured were barely even 31s, though they were old and worn. I had a 650x16 truck retread on an LJ rim (measured 28.5x6 and weighed about as much as my 30x9.5 km2s on 15x7s) on the tailgate of my SJ40 for about 2 weeks before substantial cracks formed on both the tub and the tailgate.
jono165
Joined: Thu May 27, 2010 12:01 pm Posts: 834 Location: Melbourne
 Posted: Sat Jun 23, 2012 5:08 pm |
7.00R16 / 700-16 is the perfect size to match a 31" tyre. Just find a 16x4.5" LJ/Stockman rim for it. Try and find on with the lowest load/ply rating to save weight too.
3cyl
 Posted: Sat Jun 23, 2012 5:28 pm |
I have 2 sets of 7.50/16s here (none on rims which would lower them slightly) the Dunlop Road Grippers measure 32.25", have done about 20000km and the Insa Turbos measure 32.75 (retreads) and have done about 1500 HARD LJ kms. Measured the circumferences.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Mon Jun 25, 2012 12:05 pm |
3cyl wrote: I have 2 sets of 7.50/16s here (none on rims which would lower them slightly) the Dunlop Road Grippers measure 32.25", have done about 20000km and the Insa Turbos measure 32.75 (retreads) and have done about 1500 HARD LJ kms. Measured the circumferences. Are the Grippers for sale? How much please?
Tyron
Vehicle: ***
 Posted: Mon Jun 25, 2012 12:45 pm |
sideways wrote: 3cyl wrote: sideways wrote: ROAR99 wrote: looking for a tyre to put on the factory spare rim (w/t sierra) runin 31/10.5/15 on the car but wanted a skinny 15" same hight as the 31,s amy suggestions? Basically, no. Not unless you consider 9.5" skinny. You'd be better off sourcing a 16" rim and wacking a 7.50x16 on it. 7.50x16s almost always measure 31" and are very cheap and easy to get. Most 7.50/16s are between 808 and 812 mm, closer to 32". only option on a 15 might be a 700/15 which would be a gay, uber heavy truck tyre. Most of the ones I've measured were barely even 31s, though they were old and worn. I had a 650x16 truck retread on an LJ rim (measured 28.5x6 and weighed about as much as my 30x9.5 km2s on 15x7s) on the tailgate of my SJ40 for about 2 weeks before substantial cracks formed on both the tub and the tailgate.  If you're using it as a spare, and only a spare to get you out of a situation when you need a spare tyre an inch in diametre won't be a big concern.
ROAR99
 Posted: Mon Jun 25, 2012 9:13 pm |
Tyron wrote: sideways wrote: 3cyl wrote: sideways wrote: ROAR99 wrote: looking for a tyre to put on the factory spare rim (w/t sierra) runin 31/10.5/15 on the car but wanted a skinny 15" same hight as the 31,s amy suggestions? Basically, no. Not unless you consider 9.5" skinny. You'd be better off sourcing a 16" rim and wacking a 7.50x16 on it. 7.50x16s almost always measure 31" and are very cheap and easy to get. Most 7.50/16s are between 808 and 812 mm, closer to 32". only option on a 15 might be a 700/15 which would be a gay, uber heavy truck tyre. Most of the ones I've measured were barely even 31s, though they were old and worn. I had a 650x16 truck retread on an LJ rim (measured 28.5x6 and weighed about as much as my 30x9.5 km2s on 15x7s) on the tailgate of my SJ40 for about 2 weeks before substantial cracks formed on both the tub and the tailgate.  If you're using it as a spare, and only a spare to get you out of a situation when you need a spare tyre an inch in diametre won't be a big concern. it will if i need to put it on the rear diff with the mini spool (100% locker) thanks for the imput guys,, i think il chase up a 16'' spare rim
abclarke
Joined: Mon Feb 14, 2011 8:19 am Posts: 1966 Location: Couridjah
Vehicle: 1985 Holden Drover
 Posted: Mon Jun 25, 2012 9:15 pm |
Good info guys! I wanted to find something skinny to put on the back door of the hard top seeing as the bigger spare wants to kinda make the door come off... Welling coming off anyway
_________________ 1989 WT Sierra.
