It is currently Sat Nov 07, 2026 3:06 am
Post Posted: Sat Jul 07, 2012 11:52 am
I am doing the falcon alternator upgrade today i cant get the cable off the starter motor from the negative battery terminal to replace it.
My question is can i earth the battery on my sierra to somwhere else in the engine bay or doed it need the be earthed to that point on the starter motor? Or do i need to upgrade the negative cable from the battery at all or just leave it?
I will be upgrading the positive to thicker gauge of course
Pls help
Post Posted: Sat Jul 07, 2012 12:51 pm
Starter/Engine Block Earthed to chassis
Battery must be Earthed to Chassis and Body
Mine works fine, Might also depend on your battery/wiring. (mine is an ultima under the pass seat+thick cable)
Post Posted: Sat Jul 07, 2012 12:54 pm
Upgrade the negative wire to match the positive wire you are using. The circuit is being completed through the negative wire back to the battery.
Post Posted: Sun Jul 08, 2012 12:07 am
I STRONGLY suggest that you have a HEAVY direct earth between the battery and the starter/engine block/bell housing/transmission - omitting this can cause some very puzzling symptoms - burnt/smoking clutch/accelerator/speedometer cables, welded/pitted transmission gears/bearings etc.
There should also be a second smaller earth cable between the battery and the chassis/body - your Suzuki would have been fitted with cables like I describe when it left the factory.
Post Posted: Sun Jul 08, 2012 12:38 am
The existing negative will usually be quite a bit larger that the original alternator output cable, and will in most cases be adequate - it's also the starter return, and in most cases the starter current draw is significantly higher than the alternator output.
Post Posted: Mon Jul 09, 2012 11:28 am
hi thanks for the replies
i know about upgrading the cables to a larger diameter due to the higher amperage alternator i was just wondering where to eather it to
all good i have it all wired up now just waiting on a pulley to finish the conversion
thanks
Users browsing this forum: No registered users and 292 guests
