| Author |
Message |
Richards75
Vehicle: Vitara 1994 5door
 Posted: Wed Feb 11, 2015 4:10 pm |
Hello everyone I'm new to this forum, i have a 1994 vitara 5 door efi with the g16b, I need to replace the engine it has a cracked block & head. I've been told I can use the baleno engine, some people say you can use the coil pack engine some say you can't? Help! I understand i need to change the cam & dizzy sum etc, from my current engine. Advice would be much appreciated, thankyou
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Wed Feb 11, 2015 4:22 pm |
Yes you can use the Baleno motor.
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Wed Feb 11, 2015 4:31 pm |
Yes you can use a baleno g16b to replace a vitara g16b
Some issues you will/may have, along with swapping the sump, oil pickup and camshaft. Oil pump - baleno oil pump has hole for crank angle sensor, will need to be plugged or oil pump swapped out for a vit one. Oil pickup - the crankshaft bearing caps may be different, meaning you need to fiddle with the oil pickup to make it fit etc. May have to drill and tap a hole to support the vit pickup.
Thats about all i can think of for now
GraphicX
Vehicle: 2000 Jimny
 Posted: Wed Feb 11, 2015 4:37 pm |
would also require one of bent's adaptor kits wouldn't he ?
Richards75
 Posted: Wed Feb 11, 2015 8:07 pm |
Thanks for the oil pump/pick up advice, I think the bell housing pattern will be the same.. I hope!
JrZook
 Posted: Wed Feb 11, 2015 8:22 pm |
GraphicX wrote: would also require one of bent's adaptor kits wouldn't he ? He's replacing a G16B with a G16B.....
Richards75
 Posted: Wed Feb 11, 2015 8:31 pm |
I was concerned about the coil pack baleno motor as someone told me I need the dizzy baleno, as long as I can put my vitara cam and dizzy in a coil pack baleno head? I'd rather use a newer engine if that works
jdk81
 Posted: Thu Feb 12, 2015 6:28 am |
Coil pack or dizzy baleno g16b doesnt matter. Plug the coil pack oil pump hole (jimbojones used a welch plug) or swap oil pumps over.
Richards75
 Posted: Thu Feb 12, 2015 7:28 am |
michaelsj70
Vehicle: 94 suzuki sierra sj70
 Posted: Sun Feb 15, 2015 8:46 pm |
Hi guys I'm new to this forum and would like some help please I have a 94 suzuki sierra sj70 with the pethetic 1.3l G13BA engine and Would like to up grade but have no Idea on what how and where to go for it so if anyone know about sierras please help
Dec
 Posted: Sun Feb 15, 2015 9:48 pm |
michaelsj70 wrote: Hi guys I'm new to this forum and would like some help please I have a 94 suzuki sierra sj70 with the pethetic 1.3l G13BA engine and Would like to up grade but have no Idea on what how and where to go for it so if anyone know about sierras please help There are many options. G16b being your best. Start with this to get an idea. The search bar is your friend. viewtopic.php?f=17&t=6423
