It is currently Sat Oct 24, 2026 8:50 pm
Vehicle: Vitara 1994 5door
Post Posted: Wed Feb 11, 2015 4:10 pm
Hello everyone I'm new to this forum, i have a 1994 vitara 5 door efi with the g16b, I need to replace the engine it has a cracked block & head. I've been told I can use the baleno engine, some people say you can use the coil pack engine some say you can't? Help! I understand i need to change the cam & dizzy sum etc, from my current engine. Advice would be much appreciated, thankyou
Post Posted: Wed Feb 11, 2015 4:22 pm
Yes you can use the Baleno motor.
Post Posted: Wed Feb 11, 2015 4:31 pm
Yes you can use a baleno g16b to replace a vitara g16b
Some issues you will/may have, along with swapping the sump, oil pickup and camshaft.
Oil pump - baleno oil pump has hole for crank angle sensor, will need to be plugged or oil pump swapped out for a vit one.
Oil pickup - the crankshaft bearing caps may be different, meaning you need to fiddle with the oil pickup to make it fit etc. May have to drill and tap a hole to support the vit pickup.
Thats about all i can think of for now
Vehicle: 2000 Jimny
Post Posted: Wed Feb 11, 2015 4:37 pm
would also require one of bent's adaptor kits wouldn't he ?
Post Posted: Wed Feb 11, 2015 8:07 pm
Thanks for the oil pump/pick up advice, I think the bell housing pattern will be the same.. I hope!
Post Posted: Wed Feb 11, 2015 8:22 pm
He's replacing a G16B with a G16B.....
Post Posted: Wed Feb 11, 2015 8:31 pm
I was concerned about the coil pack baleno motor as someone told me I need the dizzy baleno, as long as I can put my vitara cam and dizzy in a coil pack baleno head? I'd rather use a newer engine if that works
Post Posted: Thu Feb 12, 2015 6:28 am
Coil pack or dizzy baleno g16b doesnt matter.
Plug the coil pack oil pump hole (jimbojones used a welch plug) or swap oil pumps over.
Post Posted: Thu Feb 12, 2015 7:28 am
Thankyou!
Vehicle: 94 suzuki sierra sj70
Post Posted: Sun Feb 15, 2015 8:46 pm
Hi guys I'm new to this forum and would like some help please
I have a 94 suzuki sierra sj70 with the pethetic 1.3l G13BA engine and
Would like to up grade but have no Idea on what how and where to go for it so if anyone know about sierras please help
Post Posted: Sun Feb 15, 2015 9:48 pm
There are many options. G16b being your best.
Start with this to get an idea.
The search bar is your friend.
viewtopic.php?f=17&t=6423
Users browsing this forum: No registered users and 126 guests
