It is currently Sun Oct 18, 2026 11:03 am
Post Posted: Thu Sep 14, 2006 7:02 pm
what are peoples opinions on them. ie "stop smoke".
is it just a quickfix type solution to a slightly smokey engine?
curiosity killed the colt.
Post Posted: Thu Sep 14, 2006 10:25 pm
When is it smokey Jon? Start up, idle,cold or hot, full noise, back off?
Post Posted: Thu Sep 14, 2006 11:24 pm
All it seems to do is thicken the oil up and stops the amount getting past the rings or valuves same thing could be achived but replacing your oil with a heavier weight oil.
Steve W
Post Posted: Thu Sep 14, 2006 11:26 pm
Hey John I like your avatar :goodjob:
Steve W
Post Posted: Fri Sep 15, 2006 3:51 pm
smokey on startup. pretty bad, i put my hand about a foot away from the exhaust and it was spitting black particles onto it.
its a 1600 datsun carby for referance. not a zook i know, but u guys know a heap about small carby engines.
thinking of taking it to recarb at kawana, westy seemed to have plenty of success there and for not much coin.
i bought some valvoline stuff, its pretty thick, about as thick as hot toffee.
ill give it a go and see what happens.
yea, that avatar IS pretty awesome, i owe it all to you steve - wildest avatar maker in all the west
Post Posted: Fri Sep 15, 2006 3:52 pm
Post Posted: Fri Sep 15, 2006 8:41 pm
Johno Recarb is not the answer.
I feel that you may be waisting you money as that will not stop the smoke. Before you go there give me a ring and we can talk of other things to do before you add anything or spend money on it. I could do a compression test and that will tell you where the smoke is coming from. 10 Min job
Steve W
Post Posted: Fri Sep 15, 2006 9:17 pm
too late, add the valvoline stuff 'sarv
held a sheet of white paper behind the exhaust on startup and about a minute after.
dot on the right is on startup.
the wet dot is a minute after.
i think its running rich and or isn't getting enough air. (just blew out air filter with compressor to clean out junk).
would that explain the smoke.
it has poor take off and often konks out while idling.
am i on the right track?
Post Posted: Fri Sep 15, 2006 9:22 pm
pic
Post Posted: Fri Sep 15, 2006 10:40 pm
Dont worry too much about the watery black stuff. pretty normal I recon 8)
There no blue smoke is there?
Vehicle: 1994 Hard Top Sierra
Post Posted: Sat Sep 16, 2006 12:24 am
holly molly that is a big pic
Jason
Navigator for Team Casper
Post Posted: Sat Sep 16, 2006 1:28 pm
mine does exactly the same thing...thats why im not allowed to park in the garage :lol: I think mines just a mixture of water vapour going past the black interior of the exhaust and a bit of unburnt fuel until it sorts out its mixtures and so on when warm...i woulnt worry about it. Mine burns a touch of oil too though.
Users browsing this forum: Google [Bot] and 321 guests
