It is currently Tue Aug 04, 2026 6:56 pm
Vehicle: 92 Sierra bars F&R locked
Post Posted: Sun Sep 23, 2012 5:26 pm
i was wondering who has done a body lift on their sierra, what did you do with the carburetor boot to the air cleaner.
i just did a 2 inch body lift but the boot is kinking cuz the motor has dropped. does it affect the air flow at all?
Post Posted: Sun Sep 23, 2012 5:32 pm
This is what I did
viewtopic.php?f=5&t=17904&p=294567&hilit=carb+extension#p294567
Vehicle: 4wd
Post Posted: Sun Sep 23, 2012 5:33 pm
Many make up spacers or find another hose to go from carby hat to air box.
Your motor hasn't dropped, you have lifted the body, hence the term body lift.
Watch out or you'll get sued.
Post Posted: Sun Sep 23, 2012 9:23 pm
Thanks. Ill try find a spacer for the carby lid
Post Posted: Sun Sep 23, 2012 9:58 pm
You will have to make one. AFAIK
Post Posted: Mon Sep 24, 2012 8:34 am
go to Bunnings or a plumbing supply shop and look for a Vinidex female/female pipe connector that will fit over the carby, the connector is about 100mm long so cut it in half for a perfect 2 inch carby hat lift.
Post Posted: Mon Sep 24, 2012 2:08 pm
I used a 1.0 litre air cleaner, was much easier to fit with body lift.
Users browsing this forum: Google [Bot] and 353 guests
