It is currently Sat Oct 24, 2026 6:27 am
Post Posted: Fri Mar 27, 2015 7:13 pm
Hi all. Bit of a conundrum..
We have a 96 coily sj80 that we are refreshing.
We also have a crashed Jimny.
Sierra has a 8v g13ba carby with just 70k on it.
Jimny has an injected 16v g13bb with well over 100k on it (can't remember exact km)
Now, what engine do we jam into the Sierra?
Car will be the Mrs daily and lightish 4wd'ing.
Options.
A. Keep the g13ba, carb and all.
B. Keep the g13ba, but bolt on the Jimny egt and coils (is this possible?)
B1. Stock Jimny ecu.
B2. Mega squirt ecu (already have it ready)
C. g13bb head, inj, coils onto g13ba block. (pretty sure the head will bolt on?)
. . Again Jimny ecu or MS.
D. G13Bb complete swap.
So what say the forum? (other engines aren't going to be considered. Only what I ready have.)
My vote is for option C with Mega squirt..
Post Posted: Fri Mar 27, 2015 7:30 pm
G13BB. Stock.
Vehicle: WT sierra, GU CRD
Post Posted: Fri Mar 27, 2015 7:54 pm
G13ba Running bike carbs for perverse-ness
I love ZD30. :)
Vehicle: Drover pickup turk
Post Posted: Fri Mar 27, 2015 8:34 pm
As per Dan, G13BB. Don't mess with it and keep it reliable (for an engine conversion anyway).
I like the tuna here
Post Posted: Fri Mar 27, 2015 8:52 pm
G13bb with motorbike ITBs run by the MS.
Post Posted: Fri Mar 27, 2015 9:14 pm
Just had to one-up me.
I love ZD30. :)
Post Posted: Fri Mar 27, 2015 10:46 pm
G13bb stock. You get efi and the coily tank can take a fuel pump easy. (No innuendo intended)
Vehicle: Vitara 1994
Post Posted: Sat Mar 28, 2015 12:32 am
G16 just to be different
Post Posted: Sat Mar 28, 2015 7:40 am
G13bb
Post Posted: Sat Mar 28, 2015 8:18 am
G13bb with stock ecu etc.
Dont bastardise it.
Post Posted: Sat Mar 28, 2015 8:20 am
X those guys- another vote for stock g13bb
Post Posted: Sat Mar 28, 2015 6:53 pm
My only concern is that the g13bb has double the km of the *ba.
I want to do a quad care or quad efi setup but the Mrs doesn't.
Post Posted: Sat Mar 28, 2015 9:19 pm
Your missus is right!
And use the g13bb, bastardising to keep the g13ba will suck, ive been there done that. Its not worth it.
Post Posted: Sat Mar 28, 2015 11:09 pm
Also if u swap cams over the g13bb ecu and wiring will run a baleno coilpack g16b at a later date should u want to upgrade.
Post Posted: Mon Mar 30, 2015 12:42 am
G13BB with stock ECU.
Vehicle: for sale
Post Posted: Mon Mar 30, 2015 3:02 pm
definitely D. Just put a G13bb into mine and its great , easy to install just a bit time consuming integrating the loom to existing one
Post Posted: Mon Mar 30, 2015 5:50 pm
I also vote for the G13BB.
It may have more KMs, but unless someone has been very naughty and not taken care of it, 100k (or 62,000 miles) is not a lot - at least on this side of the Pacific. I replaced a perfectly-good G13A at 100000 miles for a rebuilt G16.
A modern, up-to-date fuel/air delivery system is a wonderful thing.
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Post Posted: Tue Mar 31, 2015 5:01 pm
Thanks guys. I'll have a chat to the Mrs, pull the *bb and give it a good going over to make sure it's in top condition befor chucking it in.
Is there a difference between the two gearbox's? As in is the Jimny a better design?
Actually the Jimny has an electronic speedo sensor. That's not going to work with the Sierra being a cable speedo...
Post Posted: Tue Mar 31, 2015 5:10 pm
Speed sensor/cable come off the transfer.
Users browsing this forum: No registered users and 115 guests
