It is currently Fri Nov 06, 2026 5:37 pm
Post Posted: Thu Oct 18, 2012 7:05 am
I need to maintain 43+\- 5 psi in the fuel rail of my vit G16 at full throttle with stock injectors and a extra jet that has a 4mm hole in it. Will be using a vitara tank. If I make a falcon or commodore pump fit in the vit tank module would that work?
Any other ideas?
Post Posted: Thu Oct 18, 2012 9:41 am
Does that 4mm jet have a flow rating(cc/min)? But yes a commo pump would flow more @ 3bar than a vit pump assembly.
Post Posted: Thu Oct 18, 2012 10:20 am
In Oozuks thread he show a bosch pump that he used that was a straight swap. I used the same one on my comp truck.
Can remember what tank it suits though?
Post Posted: Thu Oct 18, 2012 12:24 pm
JrZook wrote:
Does that 4mm jet have a flow rating(cc/min)? .
Possibly, I will have a look and see what I can find. I don't want to melt my motor so would prefer not to have to work off trial and error
Post Posted: Thu Oct 18, 2012 2:11 pm
Well then spill with any extra info you are hiding. Numbers are good! :D
Post Posted: Thu Oct 18, 2012 4:33 pm
Sticking a wet nitrous kit on a vit motor and the smallest fuel jet
Is a hole about 4mm, the structions say that it needs 43 pSi to work properly. Will have a look for flow rates
Post Posted: Thu Oct 18, 2012 4:51 pm
While I am at it is there any way I can arm a switch when revs are above 3000?
Jaycar sell RPM operated switch kits.
Post Posted: Thu Oct 18, 2012 4:59 pm
http://www.dynotunenitrous.com/store/sc ... roduct=216
Post Posted: Thu Oct 18, 2012 5:44 pm
I'd run a 2nd pump dedicated to the no^2
I look forward to the pics of bent conrods :mrgreen:
Vehicle: vits
Post Posted: Thu Oct 18, 2012 6:21 pm
...and I know someone who can build the kit for you
Post Posted: Sat Oct 20, 2012 8:12 am
Thanks britvit Armsup
The only jaycar kit I can find is this one which I don't think will be any good to me.
http://www.jaycar.com.au/productView.asp?ID=KC5382
Post Posted: Sat Oct 20, 2012 9:58 am
The intank pump in a vit is somewhat of a generic 38mm pump, lots of jap cars run the same size pump and aftermarket high flow ones are available that can fit in pretty easilly
Post Posted: Sat Oct 20, 2012 10:06 am
walbro gss341 255 litre per hour fuel pump rated to 500hp
Vehicle: vits
Post Posted: Sat Oct 20, 2012 11:00 am
I think this is the kit you need.....
http://www.jaycar.com.au/productView.as ... TID=965#11
Unfortunately the fella who I know who can build it for you is a shameless coke addict.....
.....it's gonna cost you at least a couple of 2 litre bottles Armsup
Post Posted: Sat Oct 20, 2012 12:10 pm
Thanks mate. Will the stock vitara injectors and pressure regulator be able to handle the pump when it isn't using nitrous?
