It is currently Fri Nov 06, 2026 6:13 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Sat Oct 20, 2012 8:00 pm
Whats the deal with roof sliders
Are they legal in QLD I was thinking of putting some on the LJ. Has anyone else got them in regoed 4b
Post Posted: Sat Oct 20, 2012 8:31 pm
Do you mean roof rack? Or exo?
Im guessing your LJ is a tin top?
Post Posted: Sat Oct 20, 2012 8:39 pm
You could make them bolt on. Think he is just talking about a slider up the a-pillar and across the roofline like alot of comp trucks
Post Posted: Sun Oct 21, 2012 6:36 am
Some driven wheels attached to the gutters would be a sensible addition given how often cars seem to fall over around here...
Post Posted: Sun Oct 21, 2012 7:12 am
Highway has them, seem good at stopping the cab getting so bent out of shape. :lol: I reckon without them a roof is a disadvantage.
Post Posted: Sun Oct 21, 2012 7:52 am
So much truth here.
I can't see how they would be a problem, but I don't know much about QLD.
Mine:
They have saved my cab a number of times.
They should be far more legal than any sort of internal cage. Vic regs permit them AFAIK so long as an object with a radius over 80mm will still "roll" over the bodywork - so in total. they can project more than 80mm away from the body.
Post Posted: Sun Oct 21, 2012 9:17 am
What pipe/bends did you use Steve?
I'm going to do the same thing with my LJ81 except I'l tie them in with the front body mounts too.
Post Posted: Sun Oct 21, 2012 9:35 am
I used 1" Sch 40 Steam Pipe - 33.4mm OD X 3.37mm WT
Pipe and bends are readily available. Pipe was from a normal steel supply, bends were from a plumbing supply shop.
The gussets to the body are 1.6mm thick.
Post Posted: Sun Oct 21, 2012 9:40 am
Cool, that's what I was planning on using due to the readily available bends. :D I am I bit worried the pipe bender wont have enough grunt to bend the pipe though.
Post Posted: Sun Oct 21, 2012 10:46 am
The ball they roll over it is 160mm diameter steve ;)
Post Posted: Sun Oct 21, 2012 10:53 am
He said 80mm radius? :lol:
Post Posted: Sun Oct 21, 2012 11:19 am
Damn skim reading :lol:
Post Posted: Sun Oct 21, 2012 11:49 am
yeah after the comp on the weekend, I figure I can save a lot of damage and be more competitive if I can slide past the trees. I want something A bit like g wagons but not down the front (even though that would be better). I recon if I come straight out from the sill and use 30-40mm water pipe it should work a treat. Im not sure if I'll go around the front or just do the sides
Post Posted: Sun Oct 21, 2012 12:09 pm
Are you going to connect to an internal cage? If not, I'd strongly recommend going down the A pillars. If you get a branch in under the slider and against the windscreen frame you're going to have carnage.
Post Posted: Sun Oct 21, 2012 5:49 pm
Im hearing you . Im trying to work out what to do about that
Post Posted: Sun Oct 21, 2012 7:26 pm
Go down the A pillar if you like having a windscreen.
Post Posted: Sun Oct 21, 2012 8:09 pm
definately a good thing. seems to be a good addition on all the winch trucks and i have seen them save a fair bit of damage numerous times
Post Posted: Mon Oct 22, 2012 12:29 pm
Pretty sure that in Queensland even an Exo is legal as Long as it doesn't protrude 150mm out from the body and doesn't have cross bracing in front of the windscreen well I think in the qld modification hand book it refers to external roof rack so can't c there would be much difference to roof slider just call them roof racks and you should be within the guidelines
Post Posted: Mon Oct 22, 2012 12:44 pm
IM doing the roof sliders thing, i'll be tieing into the internal cage, down the a pillar and fixing through the body again just at the bottom of the a pillar.
if you tie it onto the body well enough you can easily use small tube.
aaron uses 30 NB i believe
Post Posted: Wed Oct 31, 2012 3:48 pm
when you welded in the bends steve, did you use internal sleeves? or just butt weld it all together?
i am thinking of doing the same but i feel like i should put internals inside to give it a bit more strength and a bit more to weld to? interested in your thoughts
Post Posted: Wed Oct 31, 2012 7:57 pm
No, I didn't use internal sleeves. Bear in mind though in my application the cage is fully welded to the cab, not possible with a soft top.
However, there still should be no need for sleeves - Sch 40 pipe is very heavy wall compared to most roll cage tubing. Sleeves are only normally used for repair.
Steve
Post Posted: Thu Nov 01, 2012 7:22 am
yeah ok then.
i see what you mean the cab and the cage help hold each other together.
i would be welding it to my a pillar along the top of my doors and on the b pillar down to the floor and also over the back as well. that way i can keep the soft top (maybe with some modding) and only really the a pillar section will be immediatly visible.
im not one for taking off the windscreen or anything so it doesnt really worry me.
Users browsing this forum: No registered users and 74 guests
