It is currently Fri Nov 06, 2026 5:59 pm
Vehicle: 2010 Jimny JX
Post Posted: Mon Oct 22, 2012 8:31 pm
Hey guys,
I just picked up my 2010 Suzuki Jimny today and i want to get a 2'' lift but don't want to spend a bundle. My question is are there springs that are made for another car that would fit and be less costly than specialised jimny springs?
If there isn't what are you guys using out there?
Thoughts and past experience would be most appreciated.
Vehicle: 2011 jimny
Post Posted: Mon Oct 22, 2012 8:32 pm
using the normal front springs in the back will give you a 3 inch lift at the back
Post Posted: Mon Oct 22, 2012 8:46 pm
Yeah... I still want to do it properly i.e. springs and shocks. Will i need to install longer brake hoses after a 2 inch lift?
Vehicle: 2011 jimny
Post Posted: Mon Oct 22, 2012 9:01 pm
i got 2 inch lift on my jim and im going to be putting longer brake lines as when im full flex they are pritty tight and thats with a sway bar without you will def need them also have a look on this shop http://www.jimnybits.co.uk/shop/jimny/cat_1.html cheapest 2 inch lift around and probably one of the best
Post Posted: Mon Oct 22, 2012 9:04 pm
I was looking at this earlier. Have you bought anything off there? What is the shipping like. dont want to wait around for 3 weeks before it comes in...
Vehicle: 2011 jimny
Post Posted: Mon Oct 22, 2012 9:08 pm
i just got my lift from there last week :wink: took around a week and shipping was pretty cheap only 100 bucks or so ended up costing around 580aud for just the 2 inch lift to my door, wish i brought steering dampener and brake lines in same order :x
Post Posted: Mon Oct 22, 2012 9:15 pm
What sized tyres are you running? was originally thinking 235/75/15 but I'm now thinking it may stuff with the ratios too much...
Vehicle: Suzuki Jimny 2009
Post Posted: Mon Oct 22, 2012 9:21 pm
215/75/15 is as big as you want to go with stock gearing. I agree with Kristov, Jimnybits service was pretty good. I also needed the extended brake lines for just a 40mm lift. It was the rear that was really tight for me.
Vehicle: 2011 jimny
Post Posted: Mon Oct 22, 2012 9:29 pm
yeh the rear gets ridiculously tight with any lift i currently run 225/75/15 the put ratio out a little bit but i wouldn't change and they fill the guards nicer than 215s
Users browsing this forum: Google [Bot] and 75 guests
