It is currently Fri Nov 06, 2026 1:57 pm
Vehicle: Suzuki Sierra Rebuild :D
Post Posted: Thu Dec 06, 2012 10:03 pm
A mate has a 1.5l 1994 Excel which he had for his first car , he only recently stopped driving it , the engine had a rebuild and all , the little bloke gets up over 140k's flat out, and i'm looking at a sierra build up (Completely stripped , rust cut and bogged , Fire engine red paint) but I can't find the traditional 1.3L anywhere , the mates pretty content on just giving me the excel if this conversion would actually work , what do you guys think? How would I connect the transfer case? Any help is appreciated
Post Posted: Thu Dec 06, 2012 10:07 pm
Forget the transfer, what gear box are you going to find that will fit the motor in a rear wheel drive application ?
Post Posted: Thu Dec 06, 2012 10:13 pm
There was a Sierra with an excel motor on eBay a while ago, I've got no more info than that. Sounds like a pretty reasonable engine to use.
Post Posted: Thu Dec 06, 2012 10:14 pm
There was talk about this conversion a few weeks ago on here apparently hyundia motors have been used in GTI's so they maybe a close fit to a sierra box :?
Ill go find the thread now :)
Post Posted: Thu Dec 06, 2012 10:20 pm
That would be pretty good cos there are billions of them and even awesome condition ones are worthless
Post Posted: Thu Dec 06, 2012 10:21 pm
x2. Very interesting if it bolts up without to many mods
Post Posted: Thu Dec 06, 2012 10:23 pm
Ye since the engine and gearbox was free itself pretty much , and it runs perfectly hah . How difficult would it be to create a drive shaft onto a front wheel drive gearbox?
Post Posted: Thu Dec 06, 2012 10:25 pm
I read it in the ebay thread :)
weedkilla wrote:
http://www.ebay.com.au/itm/Suzuki-Sierra-Stockman-1991-twin-cam-1-5l-hyundai-motor-RWC-/150918950707?pt=AU_Cars&hash=item2323786f33
Is there any sense in this? Why a hyundai motor? Am i missing the point where this is the most random engine swap ever?
Great engine, Good power and torque, cheap as chips, and they are more common than crumpledoor motors. Entire cars can be bought for $200.
74kw@6000
134Nm@4000.
Better than a G16B!!
Makes sense to me.
Sorry i had it the wrong way around
matty_wall wrote:
People use excel gear boxes in gtis so it can't be insanley difficult. I remember seeing a really nice one for sale a while ago. I really wanted to give it a try before I did my conversion.
Post Posted: Thu Dec 06, 2012 10:34 pm
So the stockman ute guy managed it? or he just used the gearbox =l?
Post Posted: Thu Dec 06, 2012 10:46 pm
Oh no , i see. Ye he used the whole motor , how would i route the power to the back tires tho? The tranny case and a driveshaft of that?
Post Posted: Thu Dec 06, 2012 10:51 pm
You need to glue a rear wheel drive gearbox to the motor. Then make a jack shaft to go between the gearbox and transfer
Post Posted: Thu Dec 06, 2012 10:52 pm
What gearbox do you reckon would he have slotted in?
Post Posted: Thu Dec 06, 2012 10:58 pm
I reckon a standed sierra gearbox
Post Posted: Thu Dec 06, 2012 11:06 pm
Ye that's what i was thinking , If the gearbox i get from the wreckers is decent , i'll give it a Dig :D . I'll update you blokes if it works.
Post Posted: Thu Dec 06, 2012 11:12 pm
make sure you shave the rocker cover so there is no visible signs that it's a hyundai donk, the zook fanatics might reject it. :lol:
Post Posted: Thu Dec 06, 2012 11:20 pm
Hahah :lol: this may be one of the more interesting sierra conversions out there if it works :D .
Vehicle: '96 LWB trayback
Post Posted: Thu Dec 06, 2012 11:22 pm
1994 excel would be an X2, aka: it's a 4g15 Mitsubishi motor and is not built by hyundai.
Typically the GTI crowd are referring to X3 excels with the 4gek engine when they pilfer gearboxes.
The bellhousing bolt patterns are completely different. X2 runs the gearbox on the drivers side, X3 it's on the passenger side.
Whilst it's a potentially workable solution, you would most likely be the first person to use that actual engine. Also that model engine only produces around 61kw at the flywheel in stock configuration.
Post Posted: Thu Dec 06, 2012 11:25 pm
What problems occur with the bell house being on the opposite side?
Post Posted: Thu Dec 06, 2012 11:31 pm
usually it's what side the intake/exhaust runs when turning north/south
was just reading the ad, should give the old owner a buzz
I am selling for a friend so please direct ALL questions to JACK on 0447 196 810
Post Posted: Thu Dec 06, 2012 11:32 pm
I wonder if the mitsu starion- scorpion- rwdlancer -sigma boxs are suitable
Post Posted: Thu Dec 06, 2012 11:58 pm
Its only plastic so you could stamp Suzuki into it and leave people scratching their heads. :lol: Could glue a grill badge to it easy enough too. 8)
I'm probably heading to the wrecker tomorrow and I'l be surprised if they don't have one there. I might check out what the sump looks like and get a few dimensions.
They sound like the ultimate sierra conversion engine to me, light, comparable performance to a G16b, very reliable, readily available and above all else, cheap. :)
I am of course talking about the bubble shape ones, I wouldn't bother with the Lancer based ones.
Post Posted: Fri Dec 07, 2012 12:29 am
X3.
Post Posted: Fri Dec 07, 2012 12:32 am
X3.
icwatudidthere
Post Posted: Fri Dec 07, 2012 1:01 am
I'm sure I've posted this here before, but I can't find it in search.
If you were to go the hyundai path you have 3-4 options.
My pick would be the "Alpha" engine, 4gek. 1.5l, 12v sohc typically found in '95-98 excels. These are tough, cheap and common. I've had these engines running 11.5:1 static compression for N/A screamers, and running 14psi on stock internals for 70k kms. These engines are designed for factory turbo configuration for the S-coupe turbo. The only internal differences between the Aus released x3 excel engine and the turbo variant are oil squirters below the pistons, dished pistons for lower compression (8.5:1 rather than 10:1). These parts are readily available new from your local dealership.
Stock output of 69kw/130nm. You can squeeze 100kw out of these fairly easily on a stock bottom end.
If you want a stock engine, There is the 4gfk DOHC producing 75kw/130nm from a 1.5 16v dohc. But its just as easy to use the Beta G4g* engine. 1.6-2.0 litre with up to 100kw/180nm.
In the same direction, the theta II "World Engine", a joint venture between hyundai, chrystler and mitsubishi is the same basic form factor and a bolt in conversion to x3's. Unfortunately it's US market only at the moment but the 200kw/30nm power from the 2.0 twin scroll factory turbocharged engine at 18psi would sure open some eyes.
Do your research, there are some serious hyundai nuts around if you know where to look. ;)
Post Posted: Fri Dec 07, 2012 10:17 am
So would an X3 engine bolt up to a sierra gearbox? Or would I need the X3 gearbox?
Post Posted: Fri Dec 07, 2012 11:33 am
No. What on earth gave you that idea? You will need to make, or have made, an adapter plate to mount the engine to the gearbox. There may also be clutch and flywheel mods required.
Post Posted: Fri Dec 07, 2012 11:39 am
Oh , no thanks hah. I'll just look for the 1.3L . Probably find one lying around in a Suzuki Swift somewhere.
Post Posted: Fri Dec 07, 2012 11:30 pm
Apparently parahna were working on a Simler conversion not sure how it turned out worth giving them a ring and find out to see if they can lead you in the right direction
Vehicle: SJ80, SE416
Post Posted: Sat Dec 08, 2012 6:55 pm
..the same people who tell you if you fit a snorkel to your standard vitara you can drive through water deep enough to be halfway up the windscreen! :rofl:
Vehicle: LWB Sierra
Post Posted: Thu Dec 13, 2012 1:51 pm
I texted the bloke and he just said it was a sierra 5 speed.
must be a custom adaptor plate of some sort - i was looking into doing this a while ago but plans have moved onto something else.
Users browsing this forum: Google [Bot] and 45 guests
