It is currently Fri Nov 06, 2026 1:57 pm
Vehicle: sj51
Post Posted: Fri Dec 14, 2012 7:52 am
I dont have much experiance with narrow track 1.3ltr diffs
my question is, how will it handle a auto locker and 30" treps.. ?
should i just hold off on the locker till i fit wide track diffs and cromo's
im not that keen on changing cv's when i could be driving
My gearing is 3.9 diffs and 6.5 transfer.... so i have ample torque..
Post Posted: Fri Dec 14, 2012 9:19 am
Will handle it fine if you don't drive like a tard. Infact, being locked will be less strain on the driveline in the rough stuff as you can approach stuff slower and don't have shock loading of spinning wheels getting grip
Vehicle: sj51
Post Posted: Fri Dec 14, 2012 11:04 am
Yeah, i tend to crawl... not into this hard and fast approach
Just a bit concerned about the amount of torque generated from my gearing and the high traction surfaces i choose to play on.
Are the cv's the same as wide track ones?
Post Posted: Fri Dec 14, 2012 12:23 pm
Cv are the same
Post Posted: Fri Dec 14, 2012 1:34 pm
You will be fine, the CVs will last if you drive sensabily
Vehicle: sj51
Post Posted: Fri Dec 14, 2012 3:40 pm
Rad! I was going to wait till i had wt diffs and cromo's....... but in it go's i say :D
Post Posted: Fri Dec 14, 2012 6:49 pm
I ran NT 1.0 diffs with 1.3 axle/cv's in the front, for many years.
Never broke any more cv's than anyone else
Post Posted: Sat Dec 15, 2012 4:30 am
Is there any difference between 1.0L and 1.3L rear axles?
Post Posted: Sat Dec 15, 2012 6:45 am
I think they were the same,
but it was a while ago,
best wait for a confirmation
Post Posted: Sat Dec 15, 2012 9:07 am
They last pretty good if youre able to crawl and dont drive too hard.
Left foot braking made short work of my long side CV/axle :lol:
But being able to load up a chromo should the situation require is good.
Vehicle: sj51
Post Posted: Sat Dec 15, 2012 9:45 am
Once i swap in wide tracks i will run cromo for sure...
i am mostly gental on my rigs, but i dont want to be too concerned when gental wont cut it
Post Posted: Sat Dec 15, 2012 9:51 am
Thats it. I like being able to abuse the front end if i need to.
Users browsing this forum: Google [Bot] and 46 guests
