It is currently Fri Nov 06, 2026 1:11 pm
Vehicle: 85 ' Drover
Post Posted: Wed Jan 16, 2013 10:50 am
Gday,
Trying to order some new wheel cylinders while at work. (no access to car else id check myself :( )
Going through Greg from awd products, he has asked me to confirm if i have bleed nipples on just the passenger side or both sides of the wheel cylinders.
Why would there be bleed nipples on only one wheel cylinder? how do you get the air out of the side with no bleed nipple?
Anyway, can anyone confirm if the 85 drover has bleed nipples on one side or on both sides?
simliar to this i suppose,
http://store.onlineautoparts.com.au/Ite ... J510%204x4
Where it asks to confirm if bleed nipples on both sides.
Post Posted: Wed Jan 16, 2013 11:26 am
I think a drover will have bleeds on both sides, as per a swb NT. Most other sierras only have a bleed on one side. Brake fluid flows through the rh cylinder and then on to the left. Only the left side has a bleed.
Yes it does work.
Steve
Post Posted: Wed Jan 16, 2013 11:43 am
ohh that makes perfect sense.
sounds like most sierras have the rear brakes in series (single bleed) where you are saying the drover might have them in parellel (double bleed)
hmmm sounds like i had better wait till i can properly identify mine.
Post Posted: Wed Jan 16, 2013 12:19 pm
It will have bleeds on both sides.
Steve
Vehicle: 85.Ruf. rear air locker
Post Posted: Wed Jan 16, 2013 12:32 pm
My 85 Drover had bleed nipples on both sides
Post Posted: Wed Jan 16, 2013 1:38 pm
hmm well i have ordred them, both with nipples!
See how we go.
Gotta get the damn drum brake off first.
Vehicle: 86 SJ413 31's 1.6
Post Posted: Wed Jan 16, 2013 2:07 pm
You can take the nipple and a small spacer off one side and put the other side brake line in if its wrong
Post Posted: Wed Jan 16, 2013 2:43 pm
yer good point, i can probably also salvage bits from the old ones to make what i need.
Post Posted: Wed Jan 16, 2013 4:18 pm
Do you have one or two flexi lines from the chassis to the diff?
One line = one bleeder.
Two lines = two bleeders.
Users browsing this forum: Google [Bot] and 60 guests
