It is currently Fri Nov 06, 2026 4:15 am
Vehicle: 94 LWB VITARA
Post Posted: Sun Jan 20, 2013 8:15 am
Morning all just have a quik question, is a 98 sv620vh type 3 the first of the jellybean shape, I'm after a tidy auto 620 and there is one advertised in a yard here but has no pic, done a few searches and some have the previous square front and some show that model having the jellybean front, which is it?
Post Posted: Sun Jan 20, 2013 10:11 am
No. All sv's are the update vitara shape. All jelly beans are gv's, and are sq's.
Post Posted: Sun Jan 20, 2013 10:35 am
ANd the "620" refers to a 6cly 2.0 ltr. GV's had a 2.5ltr V6 (SQ625)
Post Posted: Sun Jan 20, 2013 10:58 am
You can get SQ620's. :wink:
Post Posted: Sun Jan 20, 2013 11:44 am
cheers for that peoples I did.know a that all the jelly beans were sq's but I thought that they may have just fukd the ad up, was 98 the very last year of the sv then? One other questions for ya's will.suspension.bits off a lwb vit fit on a sv?
Post Posted: Sun Jan 20, 2013 12:19 pm
Really :?
Post Posted: Sun Jan 20, 2013 1:34 pm
Really :?
You sure about that? Git any links to them?
ASFAIK there are only SQ416, SQ420 and SQ625 available here in OZ. Over seas they have a deisel motor also but never heard of a 2.0ltr V6 in a GV
Post Posted: Sun Jan 20, 2013 2:59 pm
Really :?
Yep. My appologies. I was thinking of the SQ420 :oops:
Post Posted: Sun Jan 20, 2013 5:33 pm
the last of the SV's were sold along side of the SQ's, my swb had a build date of 97 & a 99 aus compliance plate so it sat around in a yard somewhere in japan for a fair time before being put on the slow boat.
Post Posted: Sun Jan 20, 2013 6:34 pm
Went and looked at it this arvo, was a jellybean- devo. Dudes who do ads for cars in yards really don't know shite, just know how to babble a bit of wank in an ad. Anywho when I do find a decent one will my lwb gear bolt on, I know the diffs r wider but will.this effect bolting on normal vit gear?
Post Posted: Sun Jan 20, 2013 7:25 pm
what shit do you have one the 1.6, my crystal ball is a bit stoned ATM? :P
i'd swap diff gears straight up, best thing you could do to one even on a mild tyre size & if you sell the 1.6 with stock sized wheels they probably won't notice that its running 4.8's, your 94 will probably be a 22 spilne front diff the SV will be 26.
Post Posted: Mon Jan 21, 2013 5:40 am
just all my suspension, has a 2in lift on it, I thought that would be a good start, also Atari what size are your sunnies, will 15's fit or will I need to go to 16's and what size Tyre you running on yours? Cheers.
Post Posted: Mon Jan 21, 2013 8:50 am
lift kit will swap over, but the front might ride low due to the extra weight of the V6
-15 15x7's but they don't bolt up, you need to get a bit radical & give them a lick with a flap disk to fit them & be prepared to stagger the pad changes. -15 or more would make it easier, anything less i think would be more of a problem again.
Post Posted: Mon Jan 21, 2013 9:16 am
I know its a bit ghetto but do you reckon a strut top flip on the front would give that little bit extra to offset the weight? So pretty much 16's it is is what your saying I think my vit 15's are pos 10, so would be a no go unless I bought a set of 25mm or a bit more bolt on wheel spacers, but not too keen to go up that path.
Post Posted: Mon Jan 21, 2013 9:24 am
struts/shocks don't effect ride hight, springs do that bit so flipping the mount wont help but a small spring spacer would.
+10's will have zero chance of even coming close to fitting.
Users browsing this forum: Google [Bot] and 176 guests
