It is currently Fri Nov 06, 2026 9:53 am
Vehicle: 01 Suzuki GV SWB SQ420
Post Posted: Sun Jan 27, 2013 9:16 pm
I own an 01 GV SWB SQ420. Done a fair bit of reaserch..... a front locker can only be installed inside a steel housing ....an alloy to steel front diff housing swap has apparently been carried out before. Ive learnt that the mounting is different and requires modification to fit. Im hoping for Information on how to do this properly.
Post Posted: Sun Jan 27, 2013 9:37 pm
Any help would be greatly appreciated :-)
Post Posted: Sun Jan 27, 2013 9:47 pm
21 minutes... talk about impatient. :roll:
there are 2 styles of pinion mounts on the GV steel diffs, being a SQ420 you will want the early style of mount that matches the one that's fitted to your car as i believe the later mount will fowl your sump, there is heaps of info on the 2 different mounts.
depending if yours is manual or auto you might have to swap diff ratios as the steel diffs are usually from the V6 manuals.
what sort of locker do you want to fit.
oh and welcome to AZ :thefinger:
Post Posted: Sun Jan 27, 2013 10:07 pm
Thanks for the welcome atari4x4! Sorry for the slight impatience...this has been troubling me for some months now and have only just found you guys!
I have aquired a complete steel front diff housing and insides....had my mechanic double check diff ratios already to ensure they match. Only thing stopping me is the actual mounting. The mechanic said there would be a kit or at least some knowhow on making it fit.
My GV is manual.
Will be fitting the ARB type lockers front and rear :-)
Post Posted: Sun Jan 27, 2013 10:11 pm
the diff housing is a direct bolt in replacement.
Post Posted: Sun Jan 27, 2013 10:39 pm
That is music to my ears, thankyou soooo much for your time! I will tell my mechanic its supposed to fit and give him another chance!
Vehicle: Ford Maverick 4.2 Diesel
Post Posted: Sun Jan 27, 2013 10:41 pm
Just curious...where did you pick up the steep dif??
Post Posted: Sun Jan 27, 2013 10:43 pm
as i said heaps of info...
viewtopic.php?f=1&t=17866&hilit=GV+steel+pinion+mount
viewtopic.php?f=5&t=31632&hilit=GV+steel+pinion+mount
these links are dead for some reason. :(
http://auszookers.com/index.php?name=Fo ... steel+diff
Post Posted: Sun Jan 27, 2013 10:51 pm
My local wrecker sourced it from near/around Brisbane.
Thanks for the links atari4x4, will check them out! :-)
Post Posted: Sun Jan 27, 2013 10:58 pm
Nice find....
Oh and Gus has gone link crazy again
Post Posted: Sun Jan 27, 2013 11:02 pm
those links are fixed
and yes Mr AlexxxxxxxxxxxxX it's proof that the search works... :thefinger:
Post Posted: Mon Jan 28, 2013 8:10 am
I wouldnt know....everytime I need to find something....I just ask you. Problem solvered
Post Posted: Mon Jan 28, 2013 11:26 am
Where exactly did you find this???
Post Posted: Mon Jan 28, 2013 11:36 am
maybe it should read:
Glenn1209 wrote:
Done a fair bit of reaserch..... a front locker SHOULD only be installed inside a steel housing
Glenn if you're getting ARB to do the install of the lockers, make sure they're upto speed with the issue with the RHS CV not engaging properly on the side gears.
viewtopic.php?f=5&t=7557&p=102720&hilit=RD88#p102720
viewtopic.php?f=5&t=7039&hilit=RD88
Post Posted: Mon Jan 28, 2013 6:20 pm
Should get a bush to for the drivers cv
Users browsing this forum: No registered users and 548 guests
