It is currently Wed Nov 04, 2026 12:10 pm
Vehicle: 89 w/t sierra
Post Posted: Tue Feb 05, 2013 8:34 pm
G'day, need some help from some people with zook knowledge. My 89 wt Sierra won't hold an idle when I slow down at traffic lights etc and will just stall. Any idea on what is causing this? Checked spark plugs and they are okay. Thought it may have been bad fuel but I have run at least 2 tanks of fuel since it started.
Cheers guys
Post Posted: Tue Feb 05, 2013 8:36 pm
Idle jet is blocked in the carb is my guess.
Post Posted: Tue Feb 05, 2013 8:40 pm
take carby hat off, rev up the engine & with a rag bunched up in you hand smother the carby until in nearly dies, this usually sucks the crap out of the idle jets etc..... repeat as necessary.
Post Posted: Tue Feb 05, 2013 8:45 pm
Awesome thanks for quick replies guys!
Post Posted: Wed Feb 06, 2013 11:33 am
Tried your way atari but still no luck!
Vehicle: 1987 Suzuki Sierra hard top
Post Posted: Thu Feb 07, 2013 4:00 pm
Hey josh,
Had the same issue with mine, if you can't clear the idle jets by backfiring. Then I pulled off the carby pulled both lower jets out cleaned, put a small filter between the pump and carby replace the fuel filter, drain the tank and refuel tank with fresh fuel start her up should be fine:)
I spent hours tearing my hair hopefully that fixes urs and saves you a heap of time!
Cheers Rob
Vehicle: 1.3 Tin Top
Post Posted: Sun Feb 10, 2013 10:27 pm
I dunno if its the same for all sierras but there is a shut off solenoid on the front of the carb. The orrifice it goes in gets clogged very easily. Feck the solenoid off put a bolt in there. then if it happens again just take the bolt out, spray some carby cleaner in there.
Vehicle: Clown Car..
Post Posted: Sun Feb 10, 2013 11:00 pm
just posted up a thread with some REALLY good links to carb. rebuilding.. gives you pictures of what you are looking for in regards to solenoids etc if you are a lil lost.. well worth checking out.. should be in the Suzuki thread towards the top.
Vehicle: Suzuki sierra
Post Posted: Mon Feb 11, 2013 3:25 am
Check the fuel filter at the rear of the car in front of the fuel tank I removed mine and put the filter in the engine bay haven't had a problem since
Post Posted: Mon Feb 11, 2013 6:46 am
Thats An Easy Fix I Had to Pull My carby Off Twice :s
Post Posted: Mon Feb 11, 2013 9:42 am
That would have sucked and time consuming
Vehicle: SWB Sierra
Post Posted: Mon Feb 11, 2013 11:17 am
Remove the fuel cut solenoid, spray a bit of carby cleaner followed by compressed air in the opening where it was, watch the pressure though so as not to damage anything.
Don't remove the rear fuel filter, you want to keep crud out of the fuel pump. Do add a second fuel filter between the fuel pump and carby though.
Post Posted: Mon Feb 11, 2013 11:51 am
No I got rid of the back one and put one before the pump in the engine bay
Vehicle: SWB Sierra
Post Posted: Mon Feb 11, 2013 12:09 pm
That's ok then.
It's fairly common to add a filter between the pump and carb, this is what I thought you had done, but removed your your rear one.
Post Posted: Mon Feb 11, 2013 1:02 pm
Yeah that way u don't have to crawle in the dirt ether to replace it
Vehicle: Smurf Blue SJ70
Post Posted: Tue Apr 16, 2013 3:27 pm
Im actually having the same problem with mine at the moment.
There are 3 wires from the carby which go to a female connection which goes to a male connection to the car.
Sorry for being so vauge but i really dont know what it is called. From what i have seen and been told they clog up and rust VERY easily.
I will be replacing mine with bullet connections but every time i use a modeling flat head and scrape out the rust and what not it works perfectly.
Post Posted: Tue Apr 16, 2013 4:45 pm
I had exactly this problem. Fixed it real easy, tossed the engine and fuel tank and fitted a G13bb and fuel cell
Vehicle: Coil Sierra
Post Posted: Tue Apr 16, 2013 5:49 pm
Tried everything in the book. Next is a pull down, clean and put a kit through it
Users browsing this forum: Google [Bot] and 76 guests
