It is currently Tue Oct 20, 2026 7:47 am
lesspostingmorewheeling
Post Posted: Sun Jan 25, 2009 3:38 am
i did a 100 point turn in my zook today and now the diff is leaking oil everywhere
what do i do?
many thanks
Mike
Post Posted: Sun Jan 25, 2009 3:43 am
which diff? front or rear?
where is it leaking from?
is there any obvious damage to the diff?
Post Posted: Sun Jan 25, 2009 3:46 am
its towards the rear of the vehicle
the bit where the diff connects to the spining bit
there is obvious damage to the other diff could it be related?
Post Posted: Sun Jan 25, 2009 3:52 am
well no as the oil does not travel between diffs it would not be comming from the front diff and because they dont have a straight tail shaft between diffs i really doubt that it is related. Is the tailshaft damaged in anyway, like twisted or slightly bent? is the diff at the standard angle? Try draining the diff and pressure cleaning it to see if there are any cracks in around the leak.
Post Posted: Sun Jan 25, 2009 3:54 am
Sounds like the pinion seal...
Post Posted: Sun Jan 25, 2009 3:56 am
so are you saying oil travels through tailshafts?
i would try draining diff but i don't have the magical tool suzuki used to put the diff plug in
Post Posted: Sun Jan 25, 2009 4:05 am
3/8" square drive (i.e. 3/8" ratchet) :wink:
Member of C.O.R 4x4
Post Posted: Sun Jan 25, 2009 4:08 am
tried that was shit didn't work made square hole just a little bit round
Post Posted: Sun Jan 25, 2009 7:18 am
Chisel and hammer time :x. Had to do this to mine when I first got it. I could've sworn whoever put the drain plug on last must of hung off the end of a metre long bar to tighten the bastard up. Also time to buy a new drain plug. As Kenn mentioned, sounds like a diff pinion seal.
Post Posted: Sun Jan 25, 2009 1:38 pm
What have you been smoking Mike? It must have been goooood stuff!!!
Just grab the MIG and weld up anything that looks like it's leaking oil :twisted:
Post Posted: Sun Jan 25, 2009 4:14 pm
Is it possible its not your shocks and not your diffs?
Over extending or compressing shocks can cause the seals in the shock bodies to self destruct.
I've seen it happen a few times where people have put extended shackles on stock suspension (not just Suzuki's) and cried because they thought the broke their diffs.
Users browsing this forum: Google [Bot] and 219 guests
