| Author |
Message |
Mike
lesspostingmorewheeling
Joined: Tue May 06, 2008 11:30 pm Posts: 2236 Location: Under Down Under
 Posted: Sun Jan 25, 2009 3:38 am |
i did a 100 point turn in my zook today and now the diff is leaking oil everywhere
what do i do?
many thanks
Mike
_________________ [quote="Fluffy"] yeah right mate like Im gunna mov
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Sun Jan 25, 2009 3:43 am |
which diff? front or rear?
where is it leaking from?
is there any obvious damage to the diff?
Mike
 Posted: Sun Jan 25, 2009 3:46 am |
its towards the rear of the vehicle
the bit where the diff connects to the spining bit
there is obvious damage to the other diff could it be related?
Zook_Fan
 Posted: Sun Jan 25, 2009 3:52 am |
well no as the oil does not travel between diffs it would not be comming from the front diff and because they dont have a straight tail shaft between diffs i really doubt that it is related. Is the tailshaft damaged in anyway, like twisted or slightly bent? is the diff at the standard angle? Try draining the diff and pressure cleaning it to see if there are any cracks in around the leak.
kenn
Joined: Tue Nov 11, 2008 10:30 pm Posts: 1202 Location: Melbourne
 Posted: Sun Jan 25, 2009 3:54 am |
Sounds like the pinion seal...
Mike
 Posted: Sun Jan 25, 2009 3:56 am |
so are you saying oil travels through tailshafts?
i would try draining diff but i don't have the magical tool suzuki used to put the diff plug in
zooker
Joined: Sun Aug 06, 2006 11:30 pm Posts: 596 Location: Queanbeyan
 Posted: Sun Jan 25, 2009 4:05 am |
Mike wrote: so are you saying oil travels through tailshafts? i would try draining diff but i don't have the magical tool suzuki used to put the diff plug in
3/8" square drive (i.e. 3/8" ratchet)
_________________ Member of C.O.R 4x4
Mike
 Posted: Sun Jan 25, 2009 4:08 am |
zooker wrote: Mike wrote: so are you saying oil travels through tailshafts? i would try draining diff but i don't have the magical tool suzuki used to put the diff plug in 3/8" square drive (i.e. 3/8" ratchet)
tried that was shit didn't work made square hole just a little bit round
Rockhopper
Joined: Sun Jun 22, 2008 11:30 pm Posts: 1265 Location: Chipping Norton
 Posted: Sun Jan 25, 2009 7:18 am |
Mike wrote: zooker wrote: Mike wrote: so are you saying oil travels through tailshafts? i would try draining diff but i don't have the magical tool suzuki used to put the diff plug in 3/8" square drive (i.e. 3/8" ratchet)  tried that was shit didn't work made square hole just a little bit round
Chisel and hammer time  . Had to do this to mine when I first got it. I could've sworn whoever put the drain plug on last must of hung off the end of a metre long bar to tighten the bastard up. Also time to buy a new drain plug. As Kenn mentioned, sounds like a diff pinion seal.
_________________ We're riding in the Ninky Nonk!
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sun Jan 25, 2009 1:38 pm |
Mike wrote: its towards the rear of the vehicle the bit where the diff connects to the spining bit there is obvious damage to the other diff could it be related?
What have you been smoking Mike? It must have been goooood stuff!!!
Just grab the MIG and weld up anything that looks like it's leaking oil
SuperRoo
Joined: Wed Apr 16, 2008 11:30 pm Posts: 86 Location: Perth WA
 Posted: Sun Jan 25, 2009 4:14 pm |
Is it possible its not your shocks and not your diffs?
Over extending or compressing shocks can cause the seals in the shock bodies to self destruct.
I've seen it happen a few times where people have put extended shackles on stock suspension (not just Suzuki's) and cried because they thought the broke their diffs.
